X2 4800+ arrived .... CCB2E 0536 UPMW.... not really well but I will do my best. Default vcore is 1.264 v @ Ultra-D :D
woot my thread is now our thread. check the title. :D happy benching.
and that after almost 100k views. :D hehe
Cold bug is really low...236 mhz @ -34c....with -2c i also have 282 mhz. best temp is between +10c and +13c.
Its hard to bench but a little more than 3.5 ghz are available. these should be no.4 in the world.
I could only do 1.776 volts as the maximum, with higher voltage the pc shuts down in win :D
Our thread !!!!!!!!!!!!!!!!!!!!!!!!!! yeah !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I decided to kill my A64 3000+ no matter what Vcore I'm gonna use !
will post the results soon, it's a bad stepping anyway so i'm not expecting more than 3ghz @ 1.9v :down:
Tried a chip that wasn't too nice on normal temps, but suddenly it became a gianni-killer on dice!
3800+ venice WR is now MINE!:D
http://valid.x86-secret.com/show_oc.php?id=400433
nice, gratz bruce :D
What the hell !!! Very amazing chip....could you tell me the stepping ?
CAB1E 0622EPMW - I've had 6 of these I think. Some suck, but this one had a VERY nice coldbug for a B1, WR made at -17 I think.
WIN!
http://valid.x86-secret.com/show_oc.php?id=400740
Opty 156 + overall 939 non-fx WR: 4007 MHz @ 1.63v (will test more when I use my pot - using a copper heatsink with dice atm).
:D
DAMN DAMN DAMN!!!!! can't believe it!!!! you made my day...
venice wr stats:
2x gianni
2x bruce
1x stunned
opteron wr stats:
9x bruce
2x stunned
0x gianni
a black day.
but most important for me: sandiego wr stats:
2x gianni
1x bruce
0x stunned
:D
Knut that is really hard !!!!!! cant believe that there is one golden opteron 156....this is great !!!!!!!!!!!!!!!!!!!!!! :banana:
Where do you got these one ? Stepping ? cold bug ? 1.63 volts arent any voltage....
What do you think about LCBQE 0730 DPMW ?
as you know every cpu is working 200mhz better on knut's board than anywhere else. ;)
That is the chip that I waited for since last August (!). Well worth the wait, then:D
Stepping is AAB1E 0601WPMW. I also have an opty 152 with appox. the same stepping (CAB1E not AAB1E). Should do 3.9 easy when I bench it. No dice for it this time, unfortunately.
I don't remember the exact coldbug, but I think it was a LITTLE better than yours (~ -23 -25C @ WR). I had a lot of stuff to try out so I didn't REALLY push any chips this weekend. I tried a nice 4000+ claw, got it to just above 3.4GHz with 1.78v and -40C. Still 200mhz less than the WR, but this chip coldbugged at 350 MHz at those temps, so should be possible to lower the temps 20C or so I hope. I also think that AX-chips respond to higher voltages (this chip became too hot above 1.8v on dice, so no gains this time) so there may be 100MHz to get there.;)
I also tried a new 3200+ Manchester, but I need LN2 on it because of high temps at high voltages:p: Maybe I can go 10-20MHz above my old record with that one. My 3500+ clawhammer was pretty decent as well, but I have a feeling it didnt scale very well above 1.8v. if Im wrong, this chip would very well take the WR under Ln2. Same story with my 4600+ manchester ES. Got it to 3610-3620, but I could easily go down a few degrees before having coldbug issues.
Now Im testing my 940 server on air cooling and some optys I got a while ago;) Like 2 Opty 866's. Core temp says they are "Dual Core Prototypes" :D
My 856's aren't as great as my 156. Need 0.05-0.075v more than my 156 at same clocks, and similar (perhaps a LITTLE bit lower) temps.
You are a freak !!!
I got one 3200+ Newcastle again....and the opterons from the usa like 848, 240, 242 and 252....that 252 is CAB1E 0601 XXXX....some young stuff.
I looked the time for one 4000+ clawhammer but didnt find any one....i had one but there i had no ln2 ony single stage....shuold break the record very easy with higher voltages and lower temps.
Can you show me one picture of that opteron AAB1E please ?
Some new dimms arrived today --> 2x256 MB corsair xms256a-pc3500C2 rev 1.1 --> BH-5 for hell....should do 300 mhz i believe :D
What board are you using? I got an ASUS K8N-DL. Can't get the damn HTT above 275MHz, instant freeze... If you know some trick to get above that wall, please tell me!:D
Which week is that BH5 kit btw?;)
Edit: http://www.xtremesystems.org/forums/...0&d=1203627134 - I posted a pic of that156 a long time ago ;-) Which is nice, as I dont have a camera + that the chip is in my rig atm :P
Wow.. That is truly an amazing result. The highest i have gotten is 3600MHz on air with my LE-1620. ;P.
Gz to the WR
but only 2x256... :down:
Crazy BH-5 :D
I'm using this chip to try to get the WR
ADX6000IAA6CZ
CCB3F 0711VPMW
1650644C70053
:D
No superpi stable with 300 mhz...i think its only cpu-z :D
My last 2x256 mb twinmos bh-5 did 294 mhz superpi 1m...and 288 mhz prime blend !!!!
@ knut
I use a Asus SK8V with Via K8T800 chipset....i could only go to almost 280 mhz...today my opteron from the usa arrived...newest is one cab1e 0619 cpmw 252er.
board was modded for single stage today...and yesterday i testet out all the voltages...from 0.8 volts to 1.75 volts with an fx-51 by the way. 0.8 volts run with 800 mhz....best i could done.
s.i.h. !!!
Today I cracked my own 3200+ newcastle record....more than 2.9 ghz with single stage and 1.71 volts only....with default vcore i could got 2.65 ghz...but with that 1.7 volts i had almost 0c so i think ln2 will be the key for 3 ghz :D
That isnīt right...there are only a hand full of sticks of 2x512 mb bh-5 that can do 300 mhz...most of the sticks do between 275 and 290 mhz...but 300 is much away.
You have one of that good ram in your signature ;)
Today I got one 4000+ KAB1E 0631 APMW....but its not an San Diego or Athlon64 :D its something different :D:D:D
http://www.abload.de/thumb/4000opteron8138wzmbc.jpg
0631 APMW suxx :D like i said.... hehe
but that chip is very strange...
Its one with a G in the middle of the 3. line.
Another one 0631 APMW is also on way to me :D
