im running audigy 4 without any problems
Audigy 2 ZS here with P5B D. No problems
Icemat SC no problems
audigy ls no problems
same here:)Quote:
Originally Posted by stark27
Same here!!! OC or default 1x :( :( :( :(Quote:
Originally Posted by hot_fifty
Set PCİ-E Frea. 110,Quote:
Originally Posted by nunonunes
doesnt work.:( :( :( :( :(Quote:
Originally Posted by Ziwro
big lag on games!!!:( :(
someone please clue me in here. I just ordered this board, as it was recommended to me by alot of people on here to use for my E6600 OC. My goal is to hit 3.4GHz+ with this board, which seems possible right? BUT WHAT IS THIS X1 ISSUE YOUR ALL TYPING ABOUT?
try 0804 bios and increase voltage on SB , worked for me
the board seems to lower it's PCIE X16 bandwidth to 1X when overclocking. on some boards the problem is quite serious while the others dont have the problemQuote:
Originally Posted by newls1
I set all the latests voltage so the color is lilla / purpur, f.x. vFSB to 1,3, vNB 1,45 and so on... vSB at 1,6. Then my problem disapers
The solution which has most consistently worked for me over weeks.Quote:
Originally Posted by ea6gka
PCI-e frequency @ 110Mhz and SB Vcore set to 1.7V
However I do get the 1x once in a blue moon. I get rid of it with one power cycle.
SO i guess we can live with it.
Regards,
Karan
lol i solved my 1x problem by putting all mb voltages from "auto" to lowest value except for the nb at 1.45.......
so for all who have the problem : You just have to try by yourself various voltage and pcix mhz configs to solve it.....on another note pulling the power from the psu and hitting the power button to discarge the caps on every shut down / reset my system always booted with pcix at 16x
we need a new thread about this or something to many posts about it and information is spread out so noone reads it and just asks again and again
guys its simple , southbridge is responsible for controlling the pcie bus , so when we overclock the system it needs more voltage in order to keep up at X16. Just like we increase the voltage in the NB to keep it up to the FSB we want.
If it was that simple, raising SB voltage would solve everyone's prob. But that isn't the case... ;)
maybe, but i have heard people increasing the voltage and have afterwards 16X.
well i Lowered all voltages and it fixed itQuote:
There's many solution dudes. some1 works the voltage raising some1 else the pciex freq to 103+- , some1 else the bios flashing , and some1 else the pciex link to performance mode.
THere is always a way to fix it, .
you lowered but maybe auto in p5b dlx is a value lower to that of the lowest value except auto
Seeeriously doubt that
I have a P5B-DLX on order from newegg, so Im diving head first into OCing this board using a E6600. Before I start tweaking everything, I would like to know what BIOS everyone recommends here? If someone can answer me, I would be very thankful.
Be sure to turn off the HD Audio in Bios and only install the driver for your XF-i thus turning off onboard so it doesn't get all messed up. I had zero problems with the 0804 bios. I think these boards are voltage gremlins...at least I dont have a hardware tool or knowhow yet to test but software wise the probe2 & ai programs read things differently than core temp etc. I think one would be better off only installing the net connection/intel drivers wo the rest unless needed. Despite that asus green is supposed to be cool - it can get hot and doesn't turn on the fan properly to fix it with "performance" speeds. I rather have a winbond driver / reader tool & have the fans max when I need it not stuck at 1800. Voltage appeared to flux while watching cpu-id before I crashed. Am using ocz 700 & have an ups. Will keep things mildly oc until proper cooling.:rolleyes: Did a fresh install with minimal programs for now.
Hey just got me a 628B E6600 and PB5 Deluxe. Already had some of the 10th anniversary crucial ram. Using 614 bios. So far stable at 8x400, 1.35v in bios, 4:5 div, 5-5-5-12 When I try 1:1, I just get reboots. I'm at about the max for my ram. I'd like to boot at 8x400, 1:1, and clockgen up to find cpu max. I see most here are on the 804 bios. Is the consensus that they are the best? Any others with problems running 1:1?
Hey guys,
probably a noob question, but i wasn't sure where else to post it, so:
Is this 1.8/1.9V ram still an issue with this board? was there a bios update that fixed this problem? if so, which bios?
If it hasn't been fixed, is there any cheap 2 x 512 or 1GB modules you guys would reccommend that would work with this board (voltage wise) out of the box?
Thanks,
Bob
