Have you set the drive to enable 32 bit transfers in the bios?Quote:
I never even knew there was such a setting for HDs. I never saw that on my DFI NF4-DAGF before. I will look for it, but if it is not set to enable 32 bit by default, then I do not have it set.
thasp what bios did you get 450 fsb with?
1503, it was stock.
Orthos gives me 83c at full load.. this is insane. I need my watercooling to get here soon. :(
Can I use winflash with this mobo like I did with my old DFI? The mobo manufacturers must be schizophrenic - it's 2006, but they still use floppy disks for BIOS flashing.. ? :(
If you have a usb thumb drive it's the best way to flash with this mobo. Load the bios file in the usb drive and stick it in the computer. Reboot into bios and go find EZ Flash in there and it takes you to your usb thumb drive, and load the bios file from there.
How about a UMS MP3 player? I don't have a thumb drive.
Can I put the files onto a CD and go from there?
I dunno about that, maybe try it? If the pc recognize it as a removable disk type and you can store the bios file in there, I dont see why it wouldnt work. I used to do the cd method with the nv boards, but I havent try it with this one yet. Just get a usb flash drive, it's very convenient for loading basic drivers and stuff, also there are tons of them for like under $20
http://www.newegg.com/Product/Produc...ubCategory=522
I could buy a flash drive, but buying one to flash a BIOS is the wrong reason to - it should never require extra money to do what the product should be capable of doing on its own.
I load drivers by keeping my OS and data partitions seperate. I go into a setup folder, have programs and drivers in a seperate folder.
I will have to try a CD.
Do newer BIOSes let you set RAM subtimings? That's the only reason I care about this. I am annoyed at my :banana::banana::banana::banana:tacular RAM's inability to do more than boot into windows and freeze at 2.2v, 5-5-5-15 DDR900. It's 3-4-4-12 DDR 677 2.2v right now which passed lots of memtest. Even though the timings are tight for DDR2, it burns me that I'm running it below stock because I can't use the next-up divider of DDR900 with any kind of timings. :(
I've done it using my mp3 player.Quote:
Hi, I've just flashed the bios using my usb memory stick and found that it didn't reset the bios settings. Thus I will not be using this method and will go back to using Asus Flash, which does...
ChrisC
Have you pulled your heat sink and verified full contact with the surface of the CPU?Quote:
I had the same issue with my Big Typhoon (replaced with Ultra 120 now) after removing it found I had only 50% contact!
sparx
flashed to 1602 and the bios lagginess is still there.. :(
Twice. I put thermal paste on the CPU in a conservative layer, then put a small drop in the middle, like I usually do. Then I put it on, twisted it a tiny bit, and screwed it on very tightly.Quote:
Originally Posted by Sparx
I tried that BIOS option and moving it over one sata port, it's still 27 MBps on LAN transfer and even faster writing video, and sometimes 1-2 MBps.. :(
I have a xfx 8800 gtx card, and it's a delay in post with this videocard.Quote:
Originally Posted by DarthVader
I have 1503 bios.
I presume this issue applies to all 8800 GTXs rather than just the XFX one?Quote:
Originally Posted by Cornel
Are you get the 80c temp read from Core Temp Ver-0.93?Quote:
sparx
hey guys i need help. this is my first post so im not very experienced. I have read all 80+ pages and have tried everything but still cant get over 360fsb.
x6800
p5wdh mb
corsair 5400pro with those lights on them.I have already fried my new corsair8500c5 trying to get them to run at 1066. Can somebody just post a link of all bios settings i need to set to get over 360fsb please...would help me alot thanx
fAh.....so its not just me...lol........damned irritating the BIOS lag :(Quote:
Also.....when I turned on PC today the BIOS was reporting 'overclocking or voltage overclock failure'.......press F1 to go to Setup??
I don't have the thing overclocked!!........just rebooted and all was OK?.......anyone had this?
Originally Posted by Severance
Its a ram timing problem (safty feature)
when you boot at FSB 360+ the asus 975 boards
are more stricter with SPD timmings if your pushing high FSB
so when you set manual memory timings then save and reboot
it no's your ram cant run @ those speeds so it gives you a black screen
so now it then wants you to set auto SPD but the problem now is your memory is running way slack timmings
look at your SPD tables and i bet you they suck
so the only way to solve it, is buy ram that has aggrasive timings in the
SPD tables like the teams xtreem,Cellshock, Gskill, and you will boot 400 fsb with manual timings no problem.
i have found this out with my pw5 64 workstation
changed ram and no more 360 fsb bug
can boot @ 400 fsb 1.1 with memory
hope this helps alot of folks i spent ages trying to solve this.
so your saying that if i enable spd i can go over 360? cus iv tried that too.
Originally Posted by nanoprobe32
Syne24,Irenic and I got the same lag issue during post .Quote:
Originally Posted by scaramonga
:banana: :banana:
look @ your SPD tables with CPUz and post a screenshot
if i could just get it to boot with auto mem timings that would be ok cus i could just use memset to lower them? but i cant get it past 360fsb using auto spd
yes i see that timings are very loose when using auto spd. But why wont it boot?
your way above your ram limit, it problay would have to run
cas6 to hit over 360
even the corsair XMS2-8500C5 have very poor SPD timings
http://img293.imageshack.us/img293/9144/cpuzei9.png
Team Xtreem PC6400
http://img152.imageshack.us/img152/3792/spdyd0.jpg
cellshock PC6400
http://img91.imageshack.us/img91/4263/cellshockih9.jpg
so guess out of those 3 rams that will run into the 975 bug
corsair compatable spd timings myth
the Team Xtreem PC6400 and cellshock wont have the FSB bug over 360
simply because their programmed correctly.
