thanks:toast: Took around 15 minutes to fill and bleed with one of the big syringes they sell on DD. The PA makes a good res for traping air when its standing uprightQuote:
that sounds cool...thanks for the tip :toast:Quote:
Originally Posted by _G_
Originally Posted by funkflix
RASS CLAT didnt know those cards were so long.....anyways ok setup not the best i have seen, too much junk hangin off, res an rad out side the case,.....will post mine soon..... i give it a 4 out of 10
Like Phelan said, not a competition but please do post yours. This thread is always a nice source of ideas for cleaner looking systems :toast:
Anyway, liquid_cooled's systems is just :slobber: :slobber:
http://img.photobucket.com/albums/v4...i/IMG_0286.jpg
G11 + white CCFL (I think) looks so damn hot that I'm doing that combination on my next case
beautiful bullit. love it!
a very clean install on that bullit. only cons is small tubing.
(hmm would also suggest we maintain some General Patronage rating for those young ones)
Nice case old Brawd but still not good enought, funny, coolermaster cases are always good to work with, one would say they are the best aftermarket cases on the market.Quote:
Originally Posted by Boiller
Sorry you had to put up with that guys:( Its sorted now though.
Regards
John.
Nice pictures people. Getting some nice ideas for my case :)
Just a quick question though..do any you have performance numbers of not having a water res vs having one? Im starting to lean towards not having one..I was just going to do CPU first..and add the GPU later when new g80 cards come out. :)
Unless I'm confused a res is just to put more surface water to dissipate heat faster right?
Well so far people have resevoirs to bleed air bubbles out of their system. Running a t-line can take you an hour or even longer to bleed out the entire system, while running a res it might take you seconds.Quote:
Originally Posted by markopoleo
Temps should be the same running a system with a res vs. a system without one.
Thread cleaned. Back on topic. :)
much thanks mods.
i cant wait, i finally got my new mobo after 3 weeks, so now i can put all ma updated WC parts in and hopefully have some nice pics worthy for hte thread to come in here. loop rebuild here i come!
Very, very nice Boiler. Any more pics? What kind of coolant are you using to get the blue effect? I have some pentosin on the way for mine.Quote:
Great job on the tubing!
I believe he was just referencing that case.
My case.. this mod is actually pretty old now :)
http://img524.imageshack.us/img524/1989/img0669yi5.jpg
http://img239.imageshack.us/img239/7078/closeyi5.jpg
Fired up with UV
http://img520.imageshack.us/img520/9730/nataatxi8.jpg
NysoO nice colors you have there.
Sick rig dude. Specs??
@Xion: That's not my case, it's Liquid Cooled's as I refered. His case is at page 17 (max posts/page). But it does look damn nice. I think his coolant is Pentosin G11, atleast it's the only one I know that does that sexxxxxai crystal clear blue at 90/10.
@NysoO: Pretty big and very nice! Those cables block the view a bit though. Like the colors :toast:
@septim: Thanks :)
@NickS: Nothing special really.
CPU: Intel P4 NW, 2,8ghz @ 3,4ghz, Maze3
GPU: X800pro, Maze4
Reservoir: Baytank single 5,25
Pump: Before I had a 1250, but I discovered that a 1048 did the trick. Its not a restrictive system.
Rad: From an old volvo, here is a pic: The rad
Motherboard: P4P8X
Powersupply: OCZ modstream 450W
@Boiller: Yeah I know, but the cables were so stiff so it was hard to make the cablemanangement nice :/
NysoO i have the same Mobo there, but my cpu is a 3.0 Prescott, could not OC pass 3.25 instability issues with stock NB sink.
I had a northwood 2.8 before, should not have upgraded to the Prescott tsk tsk...
i know what you mean by stiff tubing, looks same as mine which i had to muscle behind my mobo try via some 2inch hole i made hehehe.
you'd probably have to wire it 1 by 1 starting with the smaller wires then last the atx20/24 molex, try put them behind the elbowed bay res, and don't give up because they're stiff, you can do it!
will post soon....getting the finishing touchies on the paint job
Originally Posted by fearilicious
Welcome to XS.
<<< starts chanting "PICS PICS PICS PICS"
You cant jsut tease us like that!
Damn boiler, my tubes look nothing like that at 90/10, f'ing cloudy tubes...
