I'm gonna slit my wrists if my DFi board doesnt work with my Q9450. :(
Anyone here have used ddr2 1200 or 1300 (like Team Xtreem or Transcend aXeRam) rated in this board? Will it play nicely?
Ty.
im looking for a utility that will play nice and allow fsb change inside windows with this board, any sugestions?
Edit: I found a solution, Setfsb 2.0.b.19t and clockgenerator Y28551LFXC will work :)
Jor3lBR:
im running pc9200 OCZ flex at 1203Mhz atm and it works nice so far :)
I have a 3200icfx and a 6600 go that do not get along . It won't go past 360 fsb seems to have known issues with vista 64. My 6400 would do over 400 fsb no prob. Before I buy this board I was wondering if anyone had issues with the 6600 and vista 64. I see that this board does the same thing the 3200icfx does when booting into vista 64 with the higher end quad I belive the 9450.
Thanks,
Frank
Try here: http://support.microsoft.com/kb/929777
Hey, if anyone has a QX9650 that isn't playing nice with their board, I know a guy who is looking for a used one ;)
could anyone that runs a pretty heavely overclocked system tell me how high your pwm temp is ? mine is through the roof ~ 73*c without fan blowing at it at full load, 1.552V vcore, 1.250vtt 1.51vpll 1.40vNB. im starting to think that this is the source of my instability problem.
i can't se if i can remove the hsf when the mb is mounted, anyone care to enlighten me?
73 is really high, I wouldn't talk about stability with that high temp's on the PWM. By the way what's your config ?
GL
73 is maybe high but it is no bad - limit is about 125 degree :)
On Abit Guad GT X38 temp like that is nothing unusual.
my specs are, Qx9650 @ 4400Mhz. DFI X38 LT T2R ,2Gb OCZ flex XLC pc 9200, 74Gb Raptor 10K, 2X maxtor 250Gb,500Gb Samsung, 3870 x2, 1200W Thermaltake Toughpower. Modded Vapochill Lightspeed
so there is no fan blowing at the pwm heatsink since im using phasechange.
prime would bail out at aprox 19min, pretty much the same time that the pwm hits ~73, i put a fan on the gfx blowing at it then it went down to 54 and was prime stable again. im pretty curiouse if anyone else using phasechange has experienced the same problem?
oh and i've removed the heatsink and reaplied AS ceramiqe but still the same temps.
in smartguardian...is NB temp == "System"
and
PWM == "Chipset" ????
sry im abit confused atm. chipset = northbridge, system=pwm, i think, not totally sure but it seems logical.
ok makes sense....thanks!!
My Q9450 comes on the 17th... i will inform you guys how it performs including Super Pi's and such.
