With a BETA bios I'm playing now, I took ALL four cores of the QUAD at ~5100MHz 3D Benchable.... Unfortunately don't expect to achieve high fsb with this mobo, BUT it can bench QUADs HIGHER that many others.... ;)
The worst frequency I have achieved with this QUAD, was 5010MHz as for the 3DMark2006..... At ALL other 3D benches, it can do around 5100MHz with a peak 5200MHz..... ALL cores x 17 multi .... ;)
So higher fsb I could play under LN2 or on air was about 300 - 320MHz.... The "advantage" of this mobo with the QUADS is that you can play your rams at 2:3 with tight timmings 3 - 3 - 3 - 4 - etc. and you gain a lot by doing this....
It works PERFECT ALL 4 cores of a quad at any multi and "balance" them despite what some other mobos do out there.... ;)
ALSO it might be the only mobo that can handle the load of one "heavy overclocked" QUAD at over 350Watts..... ;)
I don't really know if this new final bios works for QUAD though....
Off course I'm waiting for those new ATI VGAs to show up, coz as for me, THIS will be the mobo that will be a winner with a CF combination.... ;)
