Originally Posted by
NecroSavant
I've got an issue with my Striker 2 Extreme mobo, and i'm just wondering if anyone has/had it, and what is the solution to that problem, if any.
My system is a Striker II Extreme mobo with bios 0507, a QX9650, 2x EVGA 9800GX2, 4 Gigs (4X1 Gb) OCZ ReaperX DDR3 PC3-10666C6, SoundBlaster X-FI Fatality, 4 HDD (2 Raptors as boot up drives for XP and Vista and other 2) and a CoolerMaster 1000W, everything put together with watercooling inside a CoolerMaster Stacker 832, and everything is in stock and in auto.
I managed to fix my system after removing 2 gigs and 1 of the 9800GX2 (don't ask me how :-P), but now i have another problem.
After unsucessfully updating my bios using a usb pen or even floppys, i thought to myself "I've used ASUS update before and it worked everytime...so why not now"...so i used the latest ASUS Update to update my bios from 0507 to 0901 from windows XP.
It worked fine on XP, BIOS succesuffly updated and it asked to restart the computer...i clicked on yes...and now the computer won't boot past DET DRAM...even worse, it seems that the computer is having hiccups...what i mean is it re-starts by itself every 3 to 4 seconds after you press the power button, and the only way to stop it is to press down on the power button to shutdown the pc completely.
I tried using clear cmos and everything, but it doesn't seem to work.
As anyone of you found this problem, and it there a way to fix it?
EDIT - Fixed the problem by removing the battery for over 3 hours :-P
