my cpu is same as ur, i got 3,2 stable with 1.38 vcore u should try, cuz 1.45 seems to be a lil much
P.S= now i got it at 3ghz with 1.3 vcore no worth of high volt and some speed, atlast if u dont bench:)
hmm i think i got some freeze with 1.4v at 3.2 when i was running prime, ill try again and see what will happen
Hi All...
Spec :
Q6600 G0 (dont remember batch) sunbeam tuniq tower 120 (fan sytche 1900RPM 110 CFM )
Asus P5K-E/ap-solo
Gskill Pc2-6400 4-4-3-5
e-vga 8800GTX
this is my results with 3.4 :
http://i27.tinypic.com/sonvut.jpg
http://i30.tinypic.com/etgqvs.jpghttp://i32.tinypic.com/1zv3atd.jpghttp://i31.tinypic.com/24zly79.jpg
NB -1.40
SB - 1.20
Vpll - 1.60
Vfsb - 1.30
Vdimm - 2.2
VID - 1.2625V
what do you think?
...Just skip right over me...
update:
some of the first OC benchies on my Q6600
L740B269 @ 3.8GHz (423x9) 1.36v load - VID 1.225v
http://img99.imageshack.us/img99/8679/oc3800dm6.png
:up:
Hope it does better than 12mn Prime95 ;)
But looks like a nice chip. We have quiet near batches. Mine does quiet same performance with a 3.6GHz rock solid at 1.33v, but I need 1.43 to be rock solid at 3.8Ghz even if it SuperPi at only 1.35v at 3.8GHz. Also, those batches run hot. I see you're already at 60°C after just 12mn of Prime 95 (small FFT I guess!). You'll get much hotter when you increase volts to be stable and after 1h of Prime95 small FFT
Figured I would add in my Q6600 G0 here.
Motherboard - Abit IX38 Quad GT
CPU - Intel C2Q Q6600 G0 2.4GHz@3.3GHz 1.2625VID 1.325 VCore in BIOS
HS/F - Zalman CNPS9700NT
Memory - Corsair XMS2 2GB 4-4-4-12
PSU - Thermaltake W0106RU 700W Modular
Case - Cooler Master Mystique RC-632S
DVD/CD - Asus DRW-2014L1T
GPU - XFX GeForce 8800GT(G92) 512MB
Floppy - Samsung Floppy
Hard Drive - Seagate Barracuda 7200.10 250GB
http://img159.imageshack.us/img159/1...5stablemo3.gif
How are you guys getting stable 4+Ghz benches??? What are the volts that you're giving to that thing? Is it 3Dmark06 stable?
Which of these cores do you guys reckon belongs to either respective Die;
http://img.photobucket.com/albums/v3...Difference.jpg
C1 + C4 = 1 Die ?
C2 + C3 = 1 Die ?
:shrug:
Rock stable, and I didn't try to lower the voltage yet... I'm sure it will run as good on 1.260V-1.265V..
I've also tested 3750 and it looks stable at 1.3V
http://sesion.active-servers.com/sesion/rock_stable.jpg
Wow! VID 1.20V - which batch is that?
Mine has VID 1.3V, it takes 1.43V to prime stable at 3.6Ghz :(
How can I get one with VID 1.2~1.22? Any batch in particular?
@ Sesion
Thats an amazing Vid you have there, I need 1.4V core for prime stable (450x8) with 1.25V Vid
I get 65C loaded all cores, where you get 60C loaded all cores in prime so not too jelous :D
What batch sesion? Those temps seem pretty high, I'm guessing high ambient temp, right?
