1.03b has Merom support
No reason to flash then :).
No, 1.03 works better for me...;)
got bios 1.02 now , does 1.03 help in performance/overclock and do i need to flash??Quote:
Originally Posted by stummerwinter
or better stick too the 1.02?
first ftp link doesn't work here..:mad:
As far as I read, 1.03 is better because you can diable EIST.
Under: frequency/voltage control > power master > normal mode
The ftp-link works perfect for me, but I put the files at my webspace...;)
1.03
OK. thank's stummerwinter....this worked better.
i'm gona try, 254 max for now..with 1.02
let you know
By OMEGA
modPI 1.5 XS 16M: 6m50.250s @3655.1MHz (FSB281.2MHz x 13)
http://premium1.uploadit.org/fredyam...s-by-OMEGA.jpg
modPI 1.5 XS 32M: 14m44.110s @3630.1MHz (FSB279.2MHz x 13)
Very Nice timing! Damn you guys are flying in Japan!
I need 1.03c :)
Is there someone else except me who isn't able to view the pics?
1.03c?
I just read about the 1.03b...:rolleyes:
Is this allready availible?
By kubokubo - WR spi 32mo :toast:
CPU Intel Core Duo T2600 (2.16G) QKHK ES
M/B AOpen i975Xa-YDG (Rev.00A) (BIOS: R1.03)
MEMORY TeamXtreem TXDD2048M800HC4DC PC2-6400 1GBx2 (fat body D9 chip)
VGA ATi Xpert98XL 8M (PCI)
VGA Heatsink 無し
HDD HITACHI HDS722580VLAT20 (80GB, 7200rpm, 2MB)オンボードIDE使用
CPU Cooling LN2
Grease Ceramique by Arctic Silver
PowerSupply Zippy 600GE (600W)
OS Windows Server 2003
Soft SUPER-Pi mod 1.5 XS、CPU-Z、CrystalCPUID、MemSet 1.0
etc XINRUILIAN RDH1225B、SuperTalent MemoryCooler、
Vcore、Vdimm、Vcca、Tcore、改造あり
CAS Latency Time: 4
DRAM RAS# to CAS# Delay: 3
DRAM RAS# Precharge: 2
Precharge dealy (tRAS): 4
System Memory Frequency: 667MHz
Vcore: 1.65V
Vdimm: 2.55V
Vcca: 2.06V
http://kubokubo.jp/cpu/coreduo_t2600...655_281x13.gif
are you sure its CAL930? screen is kubo and also the url :)
excuse to me it is well kubokubo :), on the database of XS it is Omega (14m44) and not cal930 (not seen a screen in 32mo of its share but can be)
Thanks boblemagnifique for your posting of KUBOKUBO's WR SPi 32M:)
Here is his 16.265s of 1M results as well.
Thanks Waus-mod for your updating his 1M result in the front page;)
By KUBOKUBO
modPI 1.5 XS 1M 16.265s @3669.3MHz (FSB282.3MHz x 13)
http://kubokubo.jp/cpu/coreduo_t2600...669_282x13.gif
Finally got AOpen M/B and here is my modPI 1M result under LN2.
A bit of surprise that FSB went up to 280MHz... only could get out 236MHz on air:D
CPU: Intel Core Duo T2600 (2.16G) QKHK 0542A843 ES
CPU Cooling: LN2 ARC Pot Rev13.0 FX
M/B: AOpen i975Xa-YDG (Rev.00A) (BIOS: R1.03) kyosen's Vmod by TAM;)
M/B Bed: ARC Bed Rev 3.32
Memory: SuperTalent T1000UX2G5 1GBx2
VGA: ATi Rage XL 8MB PCI
HDD: Maxtor 6L080P0 80GB PATA133
PSU: OCZ PowerStream 520W
Vcore: 1.620(Actual), Vdimm=2.812V(Actual), Vcca=2.504V(Actual), Vnb=1.625V(BIOS), Vio=3.71V
Remarks: ERAM2.11, MemSet1.0, AutoGear, Maxmem
modPI 1.5 XS 1M: 16.515s @3640.4MHz (FSB280.0MHz x 13)
http://premium1.uploadit.org/fredyam...y-fredyama.gif
fredyama, Done my friend ;)
PRteamjapan,
Can you post some pics of the setup... i love them
Damn board won't boot with OCZ PC2-8000 Platinum XTC :( Anyone got that memory working with Aopen guys ? :confused:
I want to see them also Fred :)Quote:
Originally Posted by Waus-mod
I tested the 1.03c BIOS here.
Same overclock, VTT option in BIOS doesn't help :(.
Nice o/c fred-san :woot:Quote:
Originally Posted by PRTeamJapan
I put myself a question, put a IHS on your cpus with DI/LN2/Caskade ?? , because me i gain only 20mhz between the fsb max air/caskade (T2500/T2600)
I wonder whether with a IHS that would not give a better contact and allows me to more go up
Thank :toast:
Thank you boblemagnifique:toast:Quote:
Originally Posted by boblemagnifique
Woops, I forgot to add that I used only graphite sheet without any IHS this time.
Also, the FSB236MHz on air was with the un-modded board & AOpen HSF so may be due to the board limitation not by CPU itself.
Besides, am a very poor OCer on air:D
As we have seen many ES/Boxed CPU goes up to mere 20-30MHz even under extreme cooling, there seems to be some kind of FSB restriction in Yonah CPUs.
@Waus-mod
Thanks for the update.
@Waus-mod & lawrywild
My wife took my Digicamera for a trip. Please wait till next time.
BTW, you can see KUBOKUBO's recent set up here
:(Quote:
has KUBOKUBO tried LN2 yet, maybe squeeze a few more mhz out of it?
New Wr?? 1m&8m:)
1M
http://cal930.sakura.ne.jp/cgi-bin/c...e/1m15s891.png
Clock(MHz):3747.8MHz
FSB(MHz):288.3MHz
Time:15.891s
M/B: AOpen i975Xa-YDG改(#1)
CPU: T2600ES
CPU Cooling: ARARE POT#2&LN2
Memory: TeamXtreemPC2-6400(DDR2-800)1GB×2
VGA: X800GTO
HDD: S-ATA WD1500ADFD
Power Supply: Zippy-500GE(3.3VMOD)
Vcore: 1.63V, Vdimm: 2.68V
OS: Windows Server 2003
MEM: 4-3-2-4 3:5
Vio:3.78
8M
http://cal930.sakura.ne.jp/cgi-bin/c...m_3m_2s297.png
Clock(MHz):3719.2MHz
FSB(MHz):286.1MHz
Time:3M02.297s
CPU: T2600ES
VGA: X800GTO
MEM: 4-3-2-4 3:5
Vio:3.78
Always thanks & congrats PRTeamJapan :toast:
