Are you referring to the paint? Its a black wrinkle finish. Case is a MountainMods Pinnacle 18.
Edited the last couple of pages ... since the thread has been MIA for a few days, I guess the rules BEAR (grrrrrrowwwllll ;) ) repeating:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Optionally, it would be nice if you could list your water cooling components.
my setup with new case..:)
^^^:up:
Its powder coated.
more pics of my 800D build :D
http://data.fuskbugg.se/skalman01/IMG_2544.JPG
http://data.fuskbugg.se/skalman01/IMG_2547.JPG
http://data.fuskbugg.se/skalman01/IMG_2541.JPG
maby i should move my pci-Ex power cables? :P
nice build Ogge Swe..
Here is my watercooled systems, with my big friends , the big watercooling friendly wood case :)
- Mcr 320
- D-Tek Fuzion V1
- D5 Vario
- Primochill Red Uv Tubing
- Ek Res 250 Ml
http://i627.photobucket.com/albums/t...n/P1000597.jpg
http://i627.photobucket.com/albums/t...n/P1000598.jpg
http://i627.photobucket.com/albums/t...n/P1000599.jpg
http://i627.photobucket.com/albums/t...n/P1000601.jpg
In tha night , need moar light though...
http://i627.photobucket.com/albums/t...n/P1000567.jpg
http://i627.photobucket.com/albums/t...n/P1000600.jpg
Grosjambon : nice case :D
Not complete, but it is up and running...
http://s681.photobucket.com/albums/v...t=b27c080f.pbw
My first contribution!! !::rehab:
http://img706.imageshack.us/img706/6943/sdc10401zp.jpg
http://img683.imageshack.us/img683/3503/sdc10362md.jpg
http://img180.imageshack.us/img180/2053/70056365.jpg
this is my current configuration:
Intel Core i7 920 @ 4,3 | Foxconn BloodRage | 6GB DDR3 Ocz XMP 1600Mhz | BFG GTX 260 | PC Power & Cooling Silencer 750W | Antec Twelve Hundred
HD 160Gb + 250Gb WD | ViewSonic VA2226w 22" | Razer Lachesis + Barracuda HP-1 | Logitech G15 + X-540
@ dunway - whoa, that's a great color combination. Loving the bright yellow case.
@ Boxegar - nice first post :up: and welcome to XS.
Very nice clean tubing scamps :up:
Any chance for a shot of the rad(s) ?
Scamp: isn't it worth to turn in horizontal plane 90 degrees pump and use some less curved fitting (eg. some 90 degrees double(tripple?) rotary which looks like consisting of two 45deg). This way tubing should still look stright from side, and one 90deg fitting less ..
Hmm, i wonder if something can be done with last diagonal piece of tubing from cpu waterblock to mosfet one :) .. some smartly placed/turned 45deg rotary magic? :)
Pretty simple compared to all to amazing work on here, but it's coming along. :)
http://i691.photobucket.com/albums/v...11105/xs04.jpg
http://i691.photobucket.com/albums/v...11105/xs01.jpg
http://i691.photobucket.com/albums/v...11105/xs03.jpg
Very nice concept, but I must say, the MurderMod wires are a little messy.
This is my first computer build ive ever done so take it easy on me.:)
http://i63.photobucket.com/albums/h1...7/SDC10184.jpg
http://i63.photobucket.com/albums/h1...7/SDC10193.jpg
http://i63.photobucket.com/albums/h1...7/SDC10191.jpg
http://i63.photobucket.com/albums/h1...7/SDC10188.jpg
:up:Nice job with the colors. That M/B is hard when it comes to getting everthing flowing togather in a build. Once again nice job! :up:
