G.Skill PC2-6400 HZ with d9gmh @ 60e.
Shall I buy them? or too much?
The guy that has them now tell me that they can play @ 1000 for 24/7 and @ 1250 for benching.
My UT P35 was able to run my newest D9 FlexXLC kit at 555FSB 666MHz C5 PL8.
http://img682.imageshack.us/img682/9...5pl8flexxl.jpg
i found a set cm2x1024-6400c3D G for sale 2.40V ver1.1 has this memory d9gmh chips or d9gkx?
there's no difference between d9gmh and d9gkx
There was a HUGE difference between my GKX and GMH kits - I reckon these particular ICs were binned pretty tight.
I've owned no less than five kits - two GKX and three GMH, all Cell Shock. Both my GKX kits could do 4-3-3-9 at 950MHz with about 2.15v, whereas all three GMH kits struggled to get above 900MHz 4-4-4-10 with 2.1v. The GKX kits did 1100MHz 4-4-4 with relative ease and were also much better with CAS 5 overclocking.
Here is a pair of my Corsair Ballistix PC2-8500 running at 2.28 volts. I have about 1.34 volts on the northbridge. These are 24-7 numbers below. Im weird I rotate between 5-7 kits for these settings. I never had any degradation or a kit burning out.:) Super Pi results for 1M are 10.5x
http://img8.imageshack.us/img8/3683/660memory.png
1 of my crucial dominators... I mean ballistix has died. I ordered some g.skill pc8800 PI heatspreaders 1.8-1.9v. They were the last kit of its kind in stock. Only need to overclock them 30Mhz to 1130 to test my q9550 at 4Ghz.
I think crucial had a higher failure rate than others using the same chips? I have RMA them and will probably get some crap back. I rma'ed the pair still running on my other pair.
here some warm-up guys, got 20sticks of corsair dominator, began to test with the best of them, Corsair dominator 10000, 1250 mhz 5-5-5-18
http://img715.imageshack.us/img715/6...1200c4232v.jpg
What vdimm you using for 1200 4-4-4 :eek: My GKX (when the other module was still functional) needed 2.3v for 1100 4-4-4 benchable.
I didn't realise dominator was D9, but now I see that the PC10000 kits used handpicked GMH ICs which at least explains that they even get to 1200 4-4-4. :D
Just picked up a 2x1GB kit of Cell Shock 1000 4-4-4 so I'm back in the game (until they die lol :mad: ). If I could run 500fsb with DDR 1200 daily I'd be a happy camper. :yepp:
Good work aslanwas, which board are you running?
Can you include MemSet next time please? :)
Where did you get all these kits?
It's good to see some people still pushing DDR2 D9! :up:
I switched to DDR3 currently ( actually, I haven't done anything in the last 3 months ), but I'm sure I will be back to D9GMH/GKX one day, I still have 3 DDR2 kits I never tested... :rolleyes:
my first D9GKX did 600 CAS4 with 2,6V :D
Thx mate, Board P35-DS4, but is going to dy or i am going to kill it :shakes: :D (max freq. is about 1400 with these RAM, with a P45, i think i could get over 1600 under cold :D:D:D:D)
I got these sticks on ebay US, but had to pay over 230€ for all of them, but it was worth as i can see :D:D:D
don't worry, be happy :yepp:
aslanwas
gj :up:
Nice results. Haven't busted out my D9 stash in quite sometime.
Here is some Buffalo Firestix Pc2-8000 D9GKX. Running 1100 CL4 @ 2.28 volts. Not sure why it is not picking up the proper model in memset.
http://img46.imageshack.us/img46/4459/110044412.png
Here is 2x512MB of Team Xtreem Dark Pc2-6400 D9GMH running @ 2.28volts. Im going to try to push these guys, since I don't mind killing a couple 512 chips:)
FSB 560 1:1 560 4-4-4-12 PL9. Im impressed with the tight timings with PL9
http://img19.imageshack.us/img19/191...6644412pl9.png
