I'm confused on one thing about this northbridge strap business. When you set it on Auto, doesn't it sometimes switch to 400 automatically then?
I was just trying out the board, I run 450x8 or 400x9 depending on which RAM kit is on the rig.
Yes, 1,5Vcore for 3600... this Q6600 is the worst I've had :(
I was hoping to get lower PL :rofl:
That kind of Volts is totally unnecessary
Hi,
I've had a similar problem too.
It seems this mobo (or more likely a buggy BIOS) doesn't like the strap to be manually selected. :shrug:
If I leave the strap setting on AUTO and select a memory frequency that uses the 400 strap I don't have any problem though. :confused:
When I forced the 400 strap my PC refused to boot.
IMHO the P5Q Deluxe BIOS still has a LOT of room for improvement.
Let's hope the guys at ASUS are working hard... :rolleyes:
Replaced my e8200 for a new e8500 since the pricedrop made it worthwhile.
And ofc, overclocking directly.
Now, I spent my whole day, trying to adjust, tweak and get it to run Orthos Blend stable, since it didnt run for a minute. Tried everything I could think of, which my brain did well indeed. This forum was great help btw ;)
However, I finnaly nailed the issue,
its fsb/ram instability.
After a day, and some coffe, some curses, and some more, I tried lower the multipel to 8.5, run 500fsb and performance level 12, and then it went trough and did run blend.
Since it worked to run blend, I figure how high I could go? currently 8.5x527fsb and 1.52vcore, I know, its high, but its just testing stuff out.:yepp:
You must have the same memory as me. I have heard a few people hitting 1200 with my kit but I have no divider for my current overclock. I am testing 1133mhz 5-5-5-15 1.94v and PL10 right now. I have my FSB strap on auto, the only strap for 1133mhz is 400 and last time I manually set that it crashed on me.
Timbosan, what memory do you have? I just got my set to pass PL10 at 1133 with SRC and MemOC charger. I am going to step down to PL9 and 8 and if those pass I am going for Moderate twister or Light if moderate fails. I run 2 hour OCCT ram tests because I have no working version of Super PI, I have Vista64 and am having trouble getting it to work.
Hmm, ok. Is there any reliable way for me to eliminate the hardware itself as the cause of my sound issue?
Just change the FSB Term Voltage... and try to find the lowest stable setting besides 1.1...
To gain some ram performance try to set Transaction booster to Manual and go as low as possible... 10 should be doable... also try to play with the Clock twister : Moderate maybe...
For the rest looks fine...
I am using NBv1.26 with 1.94 for my Ram. I am almost done testing PL9 it has made it through 1.5hours of OCCT Ram test so far. Hopefully I only have 2 more of these to run.:)
Edit: @ Leeghoofd, just a hypothetical question here, I am not there yet but which setting would give the best Ram performance PL8/Light or PL9/Moderate??
PL9 just passes. Working on PL8 now:)
Bios 0803 no go x6 multip.. an Bios 1102 can i not run x8 multip.. :confused:
E8400
but I can run,low-volt in 1102 bios :rolleyes:
Not all boards are the same. Did you flash to the 0803? It might have been your flash wasn't the best and you flashing up wrote over what it might have missed with the 0803.
this board has played quite nice with the E8600 I picked up last week
settled for 4ghz @ 1.21v
some other results are below
didnt get pass 4.7ghz (1.49v) though since my HSF is limiting the system, temps were hitting 79C
4.0ghz @ 1.21v, 24/7 setup
http://img385.imageshack.us/img385/1...rs66ey9.th.jpg
4.5ghz (10x450) @ 1.41v, prime smallFFT 8hrs+
http://img355.imageshack.us/img355/6...1818rr2.th.jpg
4.6ghz (10x460) @ 1.44v (temps starting to get high so stopped priming after 30mins)
http://img385.imageshack.us/img385/1...1818ul3.th.jpg
watercooling
E8400 @ 4.2GHZ bios 0803 1.3850v can not start multip..x6
E8400 @ 4.2GHZ bios 1102 1.3650v can not start multip..x8 did not test in now multip x6,but it comes
Hi,
New 1103 Bios for P5Q Deluxe on Asus FTP:
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...ELUXE-1103.zip
Is the 1103 on their ftp the same 1103 I currently have running on it? I should say had running on my rmaed one..
