At that point it's looking for something to boot from. Do you have a flash drive, non bootable CD or diskette inserted?Quote:
Disable legacy USB support.
You see some numbers changing on the lower right of the screen, then after "00" the screen turn black with only a blanking cursor on top left?Quote:
If yes, try to set the ICH7R to RAID mode.
I see you are using SATA optical drives, the problem is most likely involving them. Check that the SATA mode you have selected is correct for the optical drives (Native would be my first guess). Also check that the firmware on the drives is up to date.Quote:
After being unsuccessful loadind Vista Business 64 bit, I reinstalled the 32 bit version. Now my audio is distorted. I have installed the audio drivers and reinstalled both from the CD and Web site. Anyone have this problem? In Win XP it's fine so I know it's not the audio chip.
Has anyone found a utility that will allow you to up the fan speed in vista of the fans attached to the xbx2 headers? I used IDCC in XP to manually increase the header fan speeds for me but IDCC doesn't work in vista! My cpu runs a good 8-10C hotter in vista than it does in XP according to TAT and the ability to up my header fan speeds will shave off a good 2-3C for me like it does in XP. Any info would be really appreciated.
Vista has the audio drivers included. Loading the Intel ones causes the conflict.Quote:
Originally Posted by tom8881
Uninstall the drivers then make sure there are no traces of the following files left in Windows and it's subdirectories...
stacapi.dll
staco.dll
staco64.dll
stlang.dll
sfng32.sys
sfng64.sys
sthda.sys
sthda64.sys
Scan for new hardware.
Alfredo just updated Speedfan to control the chip on our boards. Still in beta so you may have to register to get it.. 4.32 beta 17Quote:
Originally Posted by astrodave
http://www.almico.com/sfbetaprogram.php
3.6? Whosajiggawhat?Quote:
Originally Posted by Speederlander
How did you do that?
Have you tried it with the BX2?
I have the BX2 with a QX6700 and I am cooking along at 3.33 (10x333)- I can go upto 348x10= 3.48.
I am using the Tuniq Tower, OCZ PC2-5400 at 1.92 Volts. CPU Stock Voltage. C1E, EIST and Watchdog is OFF.
Keep us posted, please.
I just tried the speedfan beta and it doesnt do anything to my fan speed. I changed it to 100% but they never increased like they do in idcc. I dont think it works right yet.
I need more volts to get windows up and stable, 3.6GHz prime stable is about 1.44v idle/1.4v load, maybe a tad more (but it's just too hot to let it run long term that way on air). I already posted at 4.1 GHz when I first put the chip in the Asus board because I had never reset the BIOS on it and had no intention of taking out the 6600 that was in it and overclocked. Volts then were at like 1.6 and fsb at 401, though temps were 70*C idle haha. BUT, I think this chip would fly under phase. With my tuniq I would keep it at 3.2 GHZ since I can do 3.2 GHz prime stable at 1.3v idle/1.26v load.Quote:
Originally Posted by smoothmove
The intel board is certainly dead though. Tried it with a 6600 and got the red led and no post. :(
BIOS Version 2634
About This BIOS:
February 16, 2007
BX97520J.86A.2634.2007.0216.1057
SATA RAID info:
Intel(R) RAID for SATA - v5.6.2.1002
Marvell 88SE6145 SATA BIOS – v1.1.0.34
PXE UNDI: Initializing Intel(R) Boot Agent GE v1.2.28
PXE Base Code: Intel(R) Boot Agent GE v1.2.42
Intel® Active Management Technology info:
Intel® AMT BX Firmware: v1.2.3
New Fixes/Features:
Added support for ACPI Serial Port Console Redirection (SPCR)
table for AMT SOL.
Added support for Windows Vista* Media Center OCUR Host Firmware
Support.
Added fix for ITK where Parallel Port is always hidden.
Added fix for Windows Vista* where EBIOSPost.exe had error while
returning EBU status.
I just got my D975XBX2, and i do have some problems with the Multiplier-lowering to 6...
I have disabled C1E in configuration-Mode, i have not overclocked the CPU, i disabled VT and EIST and still the CPU lowers the multiplier when in idle mode.
How can i force the Board to disable ALL powersaving stuff?
Its pretty annoying because it can cause framerate drops when gaming.
RMclock works. just set it up so that it loads at start up and it'll disable EIST.Quote:
Originally Posted by cryptocat
The BIOS is broken. Changing C1E has no effect.Quote:
Get RMClock: http://cpu.rightmark.org/products/rmclock.shtml
Originally Posted by gtj
Are you SERIOUS?!
Intel does not allow me to disable C1E? What the...
And actually i do have RMClock, but i dont wanna use a software for what one SHOULD be able to disable in the BIOS.
I might just return this board to the store... Fan-control doesnt work either...
Is this the case with all xbx2 bios atm?Quote:
Originally Posted by shimmishim
I'm working with Intel now to solve the C1E issue.Quote:
What do you mean "Fan-control doesnt work either"?
Yep. C1E has always been broken as far as I know.Quote:
You're gonna need a fairly extensively modded phase change system to handle the heat load from a quad core. It's a strange thing, these QX6700s seem to like lower volts sometimes to achieve an overclock; that is, in a few instances I've seen unsuccessful POSTs at 3.4GHz and 1.5v, but lowered to 1.4v, it POSTs and is stable.Quote:
Seems like it's only recently been recongnized then, yes? No mention of it through most of this thread as far as I can see.Quote:
Getting a custom phase tuned for high load QX6700. ;)Quote:
Originally Posted by Omastar
I agree that they like low volts. I've had mine post FAR below baseline. But the fact that it popped up at over 4 GHz with 1.6vcore (1.56 actual in BIOS) gives me warm fuzzies about its overall abilities. With well tuned phase I should be well into the 4's (I hope) on GHz with volts well below the 1.6v mark.
+1 on related to SATA opticals. I have 3 sata opticals and disabling the boot from cd ability in bios fixed that issue.
That's because most people are using cpu-z and it wasn't reporting correctly until version 1.89 which just came out. It was reporting the max multiplier, not the current multipler.Quote:
Well, there have been several tools that also did report correctly, such as RMClock.
You said your were working with Intel to solve that. (Which i do appreciate!)
Does that signify you are an employee at Intel?
Because i dont think they would change the (next) BIOS if you just told them :(
