Well according to the front panel(Which is hardware and Not Software, I know the difference) of the Vigor Monsoon II the cold plate is reading 35C right now, Of course that is cause of the uneven load due to a faulty Bios not overclocking the cpu evenly like It should and does on My P5W which is at 45C currently, The P5W is at 36C according to Speedfan 4.31, I won't use Core Temp as It doesn't come close to what the hardware is telling Me. I do pretty good in Seti, I'm 9th out of 169 team members and in 29 days or so I'll get to 8th place, I out produce the top guy right now too, Right now My Rac is 9126.88 and I only have 4 PCs too.Quote:
Originally Posted by Hassan
http://boinc.mundayweb.com/one/stats...=4709&trans=on
Also as I said earlier I don't get any reboots when the ram is set to 1:1, Just at 2:3 and that is cause the NB heatsink sucks, Otherwise It's completly stable, So the Reboots are not caused by a cpu heat problem which is FUD.
Tweaktown has a review of the Vigor Monsoon II and It's here.
The cpu is a hot Athlon FX-53 of course.
http://images.tweaktown.com/imagebank/vmon_results.gif
Of course PC Perspectives has an earlier review too(No I don't work there, I just hang out there, As It's a hobby for Me).
http://www.pcper.com/article.php?aid=273&type=expert
The Monsoon II control module also contains an audible alarm that will sound if the temperature drops below 15°C or rises above 70°C.
http://www.pcper.com/images/reviews/...ooler-Diag.jpg
