lol you dont get it?
they have the same coloured motherboard which looks like what i :banana::banana::banana::banana: out :rofl:
Your eyes are :banana::banana::banana::banana:, my motherboard is red
Here is my new server...
http://img2.putfile.com/main/12/34718201593.jpg
I'll put some more when it's done.
It's going to be totally Red and Black..
Getting Phenom ready!!!!!
Going to build a phenom home server. Will go 4GB and a phenom B3 stepping cpu.
Sold off my FX60, got a 4800X2 brisbane (stand-by cpu until phenom B3 are out), 2.5Ghz, 65nm, 65Watter with a MSI K9A2 platinum. Cooled by a old sckool thermalright SI97A! :D
http://img.photobucket.com/albums/v4...5/P1030143.jpg
http://img.photobucket.com/albums/v4...5/P1030144.jpg
ragnarok95, you've rather colourful rig =).
^^ MSI and GIGABYTE both make crazy MOBOs
ragnarok95, should the ballistix memory be in the same lane?
On other note, is this because of MSI mobos posistion their DIMM slots abit differently than they do on some other mobos, e.g. the way you've posistioned your memory for dual channel?
ragnarok i noticed your not running dual channel correctly.Is that intentional?
Ram layout for AMD and intel for MSI are diff.
Yes, mine are running at dual channel ;)
Dun worry guys, its confirm in Dual Channel mode.
Both CPU-Z and AMD Overdrive confirm its in dual channel.
So as the mobo instruction book! :D
It's winter and my house was cold until I turned this server on..
After an hour, the room was nice and comfortable..
:shrug: I need 4Tb because I have 4Tb of data..
It's awesome for Lan Parties.. It's attached to a Dual Giga-Lan. People surf and take what they want and sometimes add some stuff I don't have..
waiting for TR to send me my gpu heatsink.
http://Ar3s.fileave.com/IMG_0181.JPG
i have the same mobo, what kinda of temps are u getting on the northbridge?
i get anywhers from 32C to 37C ( i re-pasted them with artic silver 5)
i experimented with a fan blowing on the bottom heatsink(northbridge) and it definitly helps keep it at a constent 32C
though i want to upgrade to a thermalright NB cooler. but i would have to modify the heatpipe cooler.
i notice the heat sink by the cpu socket (im assume there are the power regualtors thingys) the heatsink doesnt touch half of them. im kinda concerned about this, but it has been pretty stable. so i dunno
