lanfest 3-3-3-8 500 3.4v
http://valid.canardpc.com/show_oc.php?id=912516
tracer 4-4-4-12 640 3.4v
http://valid.canardpc.com/show_oc.php?id=912472
Yea the voltages are pretty high but them ram didn't want to overclock with voltages less than 3v.
I'm waiting for a kit od CellShock red devil and two kits od crucial lanfest and DFI Infinty P965, It's gonna be a little CAS3 party :banana:
I will also try to push up my great KHX 1200 ;)
2*1Gb Dominator PC9136 @455Mhz, 3/3/3/3 1T, 2.51v bios and Asus P5N-E (old 650i powered :D)
11000 Mb/s achieved :up: :
http://img44.imageshack.us/img44/6552/everestcas3.jpg
Blue screen just after 11255 Mb/s @457Mhz :p: I'm waiting for low temperatures :D
They both are degraded.
Today I got some good stuff :D
However, I still don't have any Mobo, waiting for Infinity P965
http://img209.imageshack.us/img209/6714/pict0001a.jpg
I have, what I've been looking for 3 months - cellshock red devil and team 1200, so if died tommorow, I wouldn't be fed up :D :
http://img64.imageshack.us/img64/8878/pict0003x.jpg
omg nice, I've been looking for all of these kit myself, but never've been lucky :(
wiesz, to nie zabory, nie ukamienują nas za używanie polskiego :D
teamy to długa historia, cellki od jacekcz'a więc jestem 2. właścicielem, ale wszystko z PL
jbc. jestem 'pastel' na purepc ;)
I wrote to Sheri that almost all my mems are from poland, imported by first owner, I'm often te second one.
Ok, it's enough. words and words only. It's time for some OC Report ;)
Nice collection JULO. :D
http://img13.imageshack.us/img13/612...hz4441229v.jpg
validated with 670mhz 4-4-4-15@ 3V on P35-DS4, but validation file CPUZ 1,52:(
reached 680mhz 4-4-4-15@ 3V but no validation
aslanwas #2088
Very good.
Memory stock cooling?
Which stepping of GKX IC's you guys think is the best?
I suppose it's 6TD22. 6XD22 on Team 1200 reviewed by xbitabs was about 15MHz worse A CAS4 than mine 6TD22 with same config.
6WD22 is something about 895MHz @ CAS3 @ 2.45V w/ Brainpower
or it's just a lottery ? :D
I do not think that goes a step, I had 3 kit of D9GKX and the best were those of 2007 (for example: 1066 4-4-4-4 2.15v or 800 3-3-3-9 2.3V) (and it was the ram of Hiwa ..)
ps: the mobo that I used with D9GKX of 2007 was the P5K therefore quite coarse in voltages, not the UD3R
http://img210.imageshack.us/img210/6948/208vdimmm.png
By sgtsixpack at 2010-01-17
I am using 4 x 1Gb crucial ballistix 16FD5. D9GMH according to google. Other marking is CL1118F.CJ & other pair CL1118L.Z8. I RMA'ed my first set and bought another in the meantime. I wasn't happy with two installed so I bought some corsair twinx XMS 4Gb which I ran at stock for till now when I needed the ballistix again to run 5:6 divider on p5q deluxe with q9550.
Just FYI I paid £127.76 for the first set from komplett.co.uk 10/4/07 & £43.46 16/12/07 (december) from dabs.co.uk. I also paid £35.64 on 08/12/2008 for the 4Gb Corsair kit. It was June 09 when the price of DDR2 hit rock bottom.
I bought a kit of OCZ Flex 9200 off ebay recently, the original revision rated up to 2.35v that uses Micron chips. 650MHz C5 on the 2:3 divider was pretty easy on the UD3P.
http://img168.imageshack.us/img168/7...l7flexxlc3.jpg
ok guys...do bad axe II eat d9's for breakfast. It's been a while since i OC'd and everything has been stock for the past year and half or so since i last done it. Before i had 2 Sets of ballistix tracers die and a bad axe go bad and had to rma. Do i need adequate cooling on the memory when oc'ing?
You definitely need some active cooling on the memory. I killed a few kits in my Maximus Formula before I started using a RAM cooler.
oh ok. I guess OC'ing means cooling i never. It saddens me since if you put a active cooler on it blocks the lights from the tracers and takes away the point of having the tracers in the first place. I can't believe i paid 280 for the kid when they came out i felt like a dumbass now. Any suggestions on coolers guys besides the corsair cooler?
If I post a DDR3 D9 shot can one of you possibly identify it for me?
This:
http://i140.photobucket.com/albums/r...6over1week.png
1.92v and I haven't tried lower as, as this is a WCG rig, I can't afford instability. Note the frequency, timings, 100% load and uptime of over eight days. Is this JNL, GTR, GTS...?
i dont get it, my team xtreem 1300s can do 600mhz 5-5-5-15 2.2v orthos stable, doesnt begin to error until 625mhz. yet nothing i do will stabilize it at its rated 650mhz. i have tried 6-6-6-18, pl10, 2.4 vdimm, 1.3 mch quite frankly nothing works :shakes: using the 5:8 divider as its the only one that will lets them scale to 1200 even.
