ok thanks to both of you I guess I just got a lot more testing to do :up:
will have to do it tomorrow though getting late here in +2GMT :coffee:
I read through quite a few pages of posts so I am sure this has probably been answered but I am unable to find it. Does this board handle 4x2GB of PC8000 memory pretty well? Also does it oc the Q6600 pretty good? I have ordered my 3780 X2 video card and I am searching for an x38 mobo that will be able to do crossfireX after the summer. I want to get a Q9550 in a couple of months so I have been looking at this mobo and the dfi Dart X38 mobo.
I have the cpu vcore set to 1.325 in bios. In windows it shows 1.36. is this normal for this board? I have been trying to find the read points to check it with a dmm. thanks in advance for any help.
I can't help you with the read points, but that's how my board does with vcore.
now that im thinking clearly, i realized what i was meaning to ask was wether i should try to run at the tighter straps? like the 4:5 is hard to get with high fsb, does that translate to higher real world performance per mhz? the strap i am running now is 5:6, should i try 4:5 and loosen my ram timings to make them run at 1100+ mhz...
further questions, how much attention should i be paying to the clock fine delay settings or any of the other stuff other than the 5-5-5-18 which is how my ram is rated, will they make or break a mhz hike?
dont know if this has been covered or not , but this thread is way to long for me to check.
just wanted to know if the X38-T2R has any issues with crucial ballistix 1066 ? its not listed as compatible ram on there site .im about to order this board tonight.
thanks adya
Did enybody tried instal Noctua NH U12P on it?
I've got one, but had it installed on my other board (Asus P5W DH Deluxe). On that board the heatsink was right up against my top case fans (modded Lian Li PC-A10B), and this board has the CPU socket higher up the mobo that that one. The fan clips stuck higher up that the edge of the board, too, so I had to use zip ties to hold the fan on top. If I had to put it in on this board, it would probably go horizontally.
I've got Thermaltake Armor, so it is bigger then yours PC Case.
Tell me please it would fit vertically - the NB heatsink is it not too high?
I'm not going to tell you it's not compatible but I did buy them 1 month ago and they worked great for about 1 week @ 1080 5.5.5.15 and about 2.2v and after they just remain unstable so be aware, since the new ballistix are not like the old ones diferent chips on them :( I sold mine to a friend who want OC them @ all :) but I wish I could buy the old one they work very well on our board as I know from others :D
Good Luck Adya :)
Is NB Heatsink on DFI X38 LT the same as on DFI P35 LT?
Has anyone achieved 500mhz fsb with quad?Or nearly the same?
damn .thats not what i wanted to hear. i already purchase this board.
and my crucial tracers are new.
damn now im worried.
these are the modules i bought-pc2-8500CL5 BL12864AL 1065.16fd5
not sure if those last numbers mean much.
but if anyone can confirm wether these overclock fine on this board ,id be very happy to hear from u.
* what do u mean double sided/single sided? how do i know what mine are? ive never heard of that.
thanks adya
man ur really scareing me here ! i had a look its not easy as they have covers on both sides.
they basically have 3 layers like a sandwich. the pcb in the middle from above view seems to have circuitry and what look like chips to me on both sides. is there an easier way to tell? i thought everyone on here used crucial b. c5 i thought the c5 was good?
ok are u talking about banking configuration?
this is what ive found-
http://benchmarkreviews.com/index.ph...id=61&Itemid=1
on the chart it has 12864AA 1065 mine are the same except there AL instead of AA ,im wondering if thats a typo on that chart actually.
but on that chart all the 128's are dual banking which means mine probably are as well.
i hope ur talking about banking config . lol
then look's like you got the right one's :D
those are mine and the wrong one's http://img205.imageshack.us/my.php?i...racer_6129.jpg
compare to those the right ones
http://shrani.si/?29/Oh/1GF0dl8H/dsc05942.jpg
the heatspreader says it already.
good luck with it :)
ok thanks for the help i appreciate it. i can still cancel my order and i have to decide now if ill do that. dont want to its the best x38 board around at the moment.
but that first image of the "BAD" modules is BL12864AL1065.8FE5 mine are very similar which worries me.
mine are BL12864AL 1065.16fd5 ive got a feeling mine are as bad as ur first ones and probably not compatible with this board.
i cant read what ur second modules are , to blurry. i think it says 16Fd3? mine are 16fd5
why do they make so many ? bastards its so uneccesary. i doubt ill buy crucials again.this is ridiculas it shouldnt be so hard.
16FD5 = most likely double sided ;)
