Originally Posted by fhpchris
No ammount of software sensors are going to impress me, TECs on air have sucked for years, guess what happens when you put them on a 200w+ QX6700 instead of some 2500+ Barton?
push the pins in from the back of the board and pull the heatpipes off, they are not even hardly attached...
Do a search, Memset X64 exists, Ive even used it on my own computer with XP64.
Yes, there is no way around that, use a higher multiplier on the two cores, or use the boot.ini switch to turn off two cores. Why you are running 800 mhz, I have no clue, that is just wrong. Run 1066 or 1333. And again, your ram isnt good, so it will take alot of tweaking on memset to get it working well.
So what? OCZ Gold isnt an overclockers module, it isnt going to run what you want it to do on a board that can only run tight as crap settings.
Nothing has changed,
1) ditch the crappy TEC cooler, it isnt good. A yate-loon on a Big Typhoon would cool better.
2) get a Swiftec MCX-119 for the NB
3) get rid of the crappy ram, or take the time to use memset to tweak around it
4) learn what the bios settings actually do, dont just run things "because some random told me to"
The AW9D isnt an easy board to clock well, and starting with a Quadcore and non-micron is going to make it alot harder on you. Just give it some time and you will reap the rewards.
I initially had only minimal success with my FX60, only getting ~2950 on air.. With a proper remount(just learning how to mount well on a ihs-less cpu) I benched @ 3100 mhz on air :)
Document what settings you try, and what results they give you, and you should have more success.
