Ok I will stick to 295x9 or maybe 300x9 with ram 245.5 2-2-2-7 (7 for bandwidth :D ). It also runs way colder as it needs much less volts.
And btw Astennu, 285x9 in your sig is 2565... :stick:
Old CPU :) Got a new Opteron 165 CCB1E 0550 VPMW. But is not the King of clockers :). Need A c-ore mod on this board. My max is 1.45v in this A8R-MVP.Quote:
Originally Posted by mursaat
hi am new here as u can tell just wanted to pst my results
what program u use to reduce the screenshoots
am runnig my opteron 165 @2998mhz @1,38v i vould like to show u am in iceland
Hi all.
Received my Opty 175 0550 last week.
With air-cooling, (Thermalright XP 120) highest stable speed (dual prime) is 2.64 Ghz.
I decided to put this thing under water (dual heater core, TDX and D4), and highest stable speed is now 2.72ghz 1.55 vcore. Temps are 40 C. load.
It’s always core 0 failing.
Right now I’m running 2.7 ghz 1,52v, 10 hours dual prime stable, But for some reason super pi fails at all speeds. :slapass:
I have tested with underclocked speeds and different memory but superpi still fails (not exact in rounds).
What could be wrong? :stick:
The computer is stable in every other benchmark, game tested.
This is my timmingsQuote:
Originally Posted by cdelong
http://overvoltage.pt/forum/imagens_...gsdualcore.JPG
Strange. i had a similar problem with my old Athlon XP. Maybe A clean install of windows ? And redownload super pi ?Quote:
Originally Posted by Nightprowler_77
Welcome :)Quote:
Originally Posted by SikO
Nice resulds. Is it Dual prime stable ? Realy nice core u have there. What kind of cooling are u running ? and what is the stepping of the cpu.
If you are using the Ballistix, your problem is 99,99% DRAM related: i have a rig VERY similar to your (Opteron 175 0550 UPMW, XP 120, 2x1Gb Ballistix, CM Stacker, etc.:) )Quote:
I have tasted your same problem with SuperPi: my weak core is 1 but the core 0 seems to be able to get even 3.0 on air...
The Ballistix are by nature problematic but my Expert mobo increase the difficulty of the task: seems that i need to found the ONLY ONE(!!!) RIGHT SETTING to run perfectly my system with Ballistix ---> i'm asking over the world and of course i'm testing myself all possible settings to get them works fine.
PLUS: the 0550 UPMW seems VERY problematic itself with memory settings (at least the 175,others people reported that), especially with Ballistix ---> i have an explosive combo! :woot:
I'm sure that OC with this 175 stepping as well is restrained by Ballistix's instability
My system is game & bench tested also, without problem...BUT if you run a long session of Windows MemTest i'm pretty sure that lot of errors shows up! :eek:
:welcome: Welcome to XS. Sounds like you got a good 165. Most of us here just use this program to host ss.Quote:
http://imageshack.us
Get some pictures up so we can see your great chip. What is the stepping on it?
Nice result :woot:Quote:
You don't have to resize the image, just upload it to somewhere like...
http://www.imageshack.us and it will give you a link with a thumbnail that you can paste here :)
(or if you really must resize it then imageshack does have a resize option right there on that page)
Originally Posted by OTT
I`ll swap my Ballistix with my sticks OCZ EB after work to se if it makes thing stable. Any recommendations for best Bios / mem settings with the combintaon Opteron 175, DFI NF4 Ulta and BAllistX?
I'm still on that...
The Expert works in a (very) different way than a Ultra-D, so my settings are useless to you! (and vice-versa)
That's is why my task is even more difficult with the Expert :(
OMG :| i bought Ballistix because i did not want problems anymore :\ now it seems they are the problem :S. This realy sux.Quote:
I have got a CCB1E 0550 VPMW. Is that a problem combo ? If zo i should be looking voor new ram :'(.
maybe swap to AM2 and just run this one as it is.... I don't know anygood memory of 2x1gb exept ballistix. I would like 300 MHz. or 250 @ cl 2/ 2.5.
someone have problems with tccd memory´s??? my tccd do 300 at 2.5-3-3-6 with 2,85v.. when i put the 165 at 2800mhz the memory do only 260+/- if i put 2900 they do only 240+/- if i pass de 2950 they do only 200.. someone can help me?? :confused:
Yesterday i recieved a opteron 175 0550 UPMW0107, i did some testing but i m already at 1.568 volt to get 2970 mhz stable, how many more volt can i put on the core s to go higher, or do i have to burn in the cpu now to continue ?
Yah if your getting good temps then there is no need to take it off. I poped mine off the other day, and temps are maybe 1-2c better and the overclock is about the same.
My core0 is weak as well, core1 goes all the way up to 311x9(highest i tried) with 1.45v. Core 0 craps out after less than an hour.
Here´s one of my Opteron 170 :
http://img457.imageshack.us/img457/4...lprime1.th.jpg
It´s a 0550 VPMW
And here´s an old 0550 UPMW of mine:
http://img92.imageshack.us/img92/576...h16v4da.th.jpg
That was my first Opteron 170:
http://img284.imageshack.us/img284/5...ime7h1x.th.jpg
One of the (if not the) best Dual-Core seen so far. :clap:Quote:
Originally Posted by Pete@X
Outstanding results with heatspreader and default watercooling.
those are some sick reults bud, what a score!
What watercooling you using? and what mobo?
no one can help with the most stable timmings in a64tweaker with opteron 165 e tccd???
Can it be the memory controller in the Optys is weaker? I thought it could be better, but with the SAME settings (except lower voltage) as my Venice, using the timings on my sig, the Everest Latency was:Quote:
Originally Posted by paulopais
Venice 3000+ 300x9, 166 divider: 36.3ns
Opteron 165 300x9, 166 divider: 38.3ns
Maybe it is because the proc is dual core? Never had a DC before
if i put my bh5 memory´s i don´t have any problem.. i use my bh5 at 255 fsb and the cpu at 3000mhzQuote:
All AMD dual cores get worse memory performance than single cores. Something about the shared memory controller, you lose about 500MB/s bandwidth and judging by your results, a few seconds latency. No biggie though, performance is still better by a lot with a DCQuote:
Go to the extreme bandwidth section of the forum for help on memoryQuote:
No one is using the retail heatpipe I see ... I heard it is very good ... on par with the xp120
Why arent any of you using it
I'm using the stock heatpipe HSF. it works just fine, my temp is about 30C idle/51C load @300x9 1.275v%110%. The only problem with this HSF is that it's not as large or tall as those 120mm heatsink which can help cooling the PWMIC and RAM a little bit. I don't have a thermal sensor on the RAM but my PWMIC temp hits 65C under load.:( I'm having a SI-120 which is supposed to come tomorrow, hopefully it will cool down the PWMIC.:)Quote:
Originally Posted by Kaiser_Sose
