@brun: En par with the best blocks out there. The cpu block is very close to the Nexxxos XP block, their gpu blocks are even better than anything I've seen elsewhere so far. Very low pressure drop, still very good performance and light weight.
small update nr1:
http://www.forumdeluxx.de/gallery/data/500/SIMG2898.JPG
i cant wait to get mine put together. ive got 2 cool blue lazer cannons that im mounting in the front of my stacker 830 that will point down. plus some crazy looking fans. even got cheesy and bought this little Neon Crab Memory Cooler. it mounts on the ram and has two small mini fans :D i figure ill just wrap any wires in black sprial wire casings.
Personal preference :) . I personally think they look beautiful.Quote:
Originally Posted by Herr Brun
Usama aka Ferrari Freak
Just wondering o$$!ram, but where did you put you Hard drives ? Are you using that Caddy box that came whit the stacker ?
http://www.forumdeluxx.de/gallery/da...m/SIMG2899.JPG
sorry for the teribble quality :(
the hdd box from the stacker is not very good :sick:
Well, At first i was thinking of doing this when i got my PA120.3 Radiator. Mount it in the front and put the Hardd rives in the bottom. Havent found any ways to carefuly get the Harddrives to just sit in the bottom of the case. So i decided to make a hole in the bottom and mount\mod the rad in the bottom. Here what is gives:
http://img456.imageshack.us/img456/2...2389we6.th.jpg http://img475.imageshack.us/img475/8...2463yu1.th.jpg
Ill may try to make something similar to you and make the Hd's hold on the bttom and ill Probably again re-do my watercooling kit soon. Ill get a Strom waterblock another MCW60 (whit of course the X1900CrossFire edition card) maybe a second pump and ill mount the Rad just as you did in the front. Anyways Thanks for the Pics!
EDIT: Oh and By-the-way: Use some Coolsleves on that Horrible bending on that Outlet of your pump!
OMG? i don't understand what you telling me with your last sentence ;)
LOL! Just saying that you should use some coolsleeves on your tubing Right Here: http://img376.imageshack.us/img376/1...2899mq0.th.jpg So that your Tube does not bend like that.Quote:
Originally Posted by o$$!ram
Coolsleeves™ are extruded PVC coils designed to be wrapped around 5/8" Outer Diameter soft vinyl tubes, and eliminate tube kinking and flattening in medium to sharp bend areas.
I use some on my Tube so that it does not do what it does on your Tube where it connect to your Pump...
O$$iram, you have a bad kink at the inlet of your pump, better fix it immediately.
If Creidiki sees it he'll get a heart attack ;)Quote:
Originally Posted by thunderstruck!
Fix it quickly ossiram ... ^^
AAAAH! now i understand ... my english is not good ;)
the "knick" (bend!?) is not long there ... the next update is comming ;) this is only tempoary.
btw. look @ my sig ;)
That's what he meant, kinked tubing means that the tubing is not in its original form and doesn't have a proper ID anymore.
Coolsleeves are wraps that prevent kinking, they stabilize the tubing -> if it's just a too sharp bend, you can also use zip ties for that.
Like here:
http://i70.photobucket.com/albums/i1...8_resize-8.jpg
o$$!ram that is a simple way to mount them harddisk, much like what i had before i made my own mountain mod fan hd bracket like this:
http://img133.imageshack.us/img133/3...bracketea7.jpg
regarding that kink in the inlet, i also had that because i had 2inch over tubing, cut it to size and rebarb tubing, add them coolsleeves or cable ties and your good to go.
New platform, new WC.
http://img367.imageshack.us/img367/8901/6065we8.jpg
Wow that tubing looks so small man :eek: . At least you don't have trouble with routing though. I can't remember who, but someone on the forum cooled his NB, 2 graphics cards, his CPU, both his RAM modules, and both his HDDs, had a triple rad and 2 pumps all in one Lian-Li PC-7077 (if I remember correctly), of course he used 1/4" tubing. Colour looks nice though.
Originally Posted by Radical_53
Can you post a pic of your Thermochill on the case?
Thanks,
Luis
He's running it externally on that setup.
ill/Ill = To be sick or to be feeling sick.
i'll/I'll = a contraction of I will, as in: I'll get to work after my coffe' or I'll be cleaning up some more when I'm (I am) don.
Commas are very important, more important then spelling the word its self IMO, it can change the meaning of the whole sentance. Be nice to our forign friends, use the power of the comma!
If you are going to recommend people use commas correctly to help our "forign friends" you could atleast spell foreign correctly.
Comma?
Thought it was called an apostrophe.:D Bleh, lets go back ontopic.
It is :DQuote:
Originally Posted by Xavior
This is a comma ,
This is an apostrophe '
Get it right people :p:
Now, more pics of watercooled systems :toast:
http://www.forumdeluxx.de/gallery/data/500/SIMG2901.JPG
the radiator is now back in the top of my case ... it wasn't very good for the hdds ...
o$$!ram, where are your hose clamps? That is asking for a leak.... :eek:
