throwin down some benches today. Window open, ambient is around 17C....this board/cpu still amazes me after almost 3 months.
So there has been a lot of talk bout the temps, i need to make one thing clear i did a lot of trial and error with different thermal pastes (AS5, Tuniq, TR, OCZ freeze, zalman) it was very time consuming but after about 14 hours or so i finally figured out for my self on how different these pastes are, only as regards to the temps, also i tried different ways of putting on the paste. also tried different fans on TRUE, even tried it fanless for 15 mins to see what happens. Also tried making an air duct to pull in fresh air.
In the 14 hours I tested a lot of things for fun, i didn't take extensive logs of everything, since i was interested in only what worked best. It is way too much to post all the details, i have to get back to studying, so i am going to post my final choices.
TRUE (TR 1400 rpm fan pushing, Xigma Tech XLF-F1253 pulling)
OCZ Freeze (best way to put on put a tiny droplet, half the size of a grain of sticky sushi rice or a quarter grain size of a indian pakistani long grain basmati rice)
Procedure:
put the paste
align the TRUE perfectly and dont u dare move it even a tad bit.
put two screws cross from each other, tighten all the way so u dont risk moving the HS while getting the other two in. once the first two are tight move on to the next two, tighten all the way.
now try to spin the HS just a little clockwise the anti-clock ending up in the same position. toss on the fans.
i added two additional fans a 230mm on the door, it fit perfectly, same fan as the HF932. Another fan was added along with a 5.25-3.5 cage in the front, so it make a nice air tunnel straight across front to back.
sorry if i was unclear, i am stressing about my studies, i need to get back, i will check u guys in a bit.
For temp i am using real temp, didn't bother installing ET6
Its day time now and my idle temp has risen to 40-42, guess not fully idle because i am in window.
In bios i am getting 24-26 for cpu.
http://img144.imageshack.us/img144/8452/dsc01672.jpg
http://img144.imageshack.us/img144/d...jpg/1/w800.png
how is the sli with different cards working, i was thinking bout adding a 4870 to my 4850
sure i know i will be on xfire but u r on sli
any u recommend it, right?
nice job with TRUE technut:up:
well i am not really into pc gaming right now, because i cannot really run high resolution. i can play left4dead, css and a lot of other games on max but i dont really play old games i like to get play the new games.
i am currently playing mostly xbox 360 exclusively.
if i would be able to run crysis and some other graphic intensive games then yeah i would be interested in adding another card like 4870 or even the 4870x2.
thanx man, i have used probably 10-15 high end heat sinks in the last 3 years, and this is really the best, due to the 6 heat pipes. i wish i had the copper TRUE. this raped the corsair wc setup i had 4 years ago.
From my experience tuniq, noctua, even zalman 9700 can give a similar temp when idle but under load the TRUE destroys them. at 1.4185 set in bios my cpu under 99% load for 2 hours wont go over 64-69.
another newer HS which performs on par according to hardocp is the http://www.prolimatech.com/products/megahalems.html
this thing is cheaper and the design looks wicked.
Cooler master have another monster v10 i think it costs twice as much as a TRUE. i have v8 cooling my Q6600 its very good. i wonder how good is TRUE CU with coollaboratory liquid pro 2xultra kaze
almost below 9
http://www.saunders.fr/images/oc20.jpg
.001 Does not count! :P
Fantastic clocks guys. My board is out for delivery right now! I cant wait to see what I can get out of is.
I still have the same question if any one can shed some light on this. The Orange/ Peach colored PCI-E slots. Anyone know why they have that specific color?
trying to hit 5ghz...again...but running into ?cpuz 1.5 bug unless weird TDP limit issue. Booted 23x216 (4968) 3x and 3 different cpuz dumps...but cpuz says 4958 every time. I got 23x217 to boot but cpuz crashed before dumping but it to was off in calculation as well. 23x214 and below calculates correctly:shrug:. 10mhz is too big for spread spectrum differences...have never seen multi kick down at idle like that from TDP limits and cpuz is reading different than everest/realtemp, also dont understand the exact same error 3x:shrug: This is with computer outside, water temps is 1-2C (have antifreeze in loop).
http://valid.canardpc.com/show_oc.php?id=512681
damn rev, trying to keep up with you is proving difficult :) how are the pi's working out
awesome clock rge so close to 5GHz, i finally got bclk to 21x220 http://valid.canardpc.com/show_oc.php?id=514611
http://www.saunders.fr/images/oc22.jpg
envy i envy your setup.
Hi
First off thanks for everyone who posted here - my first overclock and I got to 21x190 on bios F5g :up:
I flashed BIOS to F6a tonight and whilst it has cured the double post issue I can no longer get to 21x190. 21x187 seems to be the best I can get, has anyone else seen a similar effect going to F6a?
I upped Vcore to 1.425 and QPi/Vtt to 1.385 (1.40 and 1.335 on F5g) but that hasn't helped.
