You've already cut the end out of the PCI-x slot?
awe had ram slot #1 die last night on one of em..
good thing i have an extra board sitting around :D
back up and runnin
so I'm guessing you just had a 24>2*24pin and an 8>2*8pin setup on the PSU to power both??
NKrader mind sharing how much and where you found the heatsinks? i feel a bit dumb to spend as much on heatsinks equal to a mobo+2 cpus+ and RAM.
You can get the motherboard, two CPUs and RAM for less than $27 + postage? The board costs $10 + postage on it's own, so you're saying you can get 2 CPUs and RAM for under $17 posted.
i over exaggerated, but i should've stated excluding shipping. The motherboard is $10, the CPUs linked are also $10 a piece now and I figured another $10 or so for the RAM. So including shipping I cant see it be more than $55-60 shipped?
From the intel site, the heatsinks alone would cost around $37 shipped to California. So i guess 33% of the total build =P.
regardless, this is a pretty cool setup for $100 US, if indeed the $13 heatsinks are the lowest around.
maybe cuz i got some TX3 for $13 apiece that I feel those are a bit pricey, and without a fan to boot. however, as u have mentioned, it seems like a steal when you take into account how specialized they are.
If you need some I do believe I have a couple 1GB sticks that work in it lying around here someplace.
endlesszeal gets first dibs if he wants them for a Sossaman since he has none :)
Do you have a sound card in it somehow?
I'm using Sossaman rigs for my kid's machines. Since they only play web based flash games and such the onboard video and a $2 USB sound adaptor work just fine.
bad luck... first the ram slot.
now had a HD die last night.. meh. i had it less than 2 weeks. time to give some neg feedback on the fleabay
If you bought the drive used and it worked for 2 weeks I'd say the seller isn't responsible. It wasn't DOA so I don't see it being his fault.
I could send you an 80GB drive for cost of shipping if you want. Just don't hold me responsible for its lifespan as it's a free item :p:
Well, I'll throw in a molex > sata power adapter then :D
Picky :p:
