2 Attachment(s)
Q9550 and G.Skill F3-12800CL7D-4GBPI stable settings 475x8.5
While you guys are having good fun playing around with core 2 duos here are some settings which I finally managed for Q9550 (C1) and the G. Skills 2x2GB:
1. 450 x 8.5 @ 1800 8-8-8-20 PL7
2. 475 x 8.5 @ 1584 7-7-7-18 PL7
I have the old Q9550 (C1) and it requires quite high voltages to run at high fsb's. Anyone with the newer (EO) cpu should achieve the above scores with much lower Vcore and Vtt.
Both cases ran 20 IBT max stress and 9 hr+ Prime Blend stable.
The higher fsb one should only be tried on water cooled systems as core temp peaked to 86C during IBT max stressing.
2 Attachment(s)
Oh btw the 450 x 8.5 was tested on both 0501 and 1003 bios.
The 475 x 8.5 tested only on 0501. will check whether it works on 1003 when I have time.
