@knet370: ganda talaga rig mo papi! :up: the more i look at your setup & Matt's, the more i wanna go into water-cooling :(
@ThatGuy16: din't you have an LCD at the side panel before? or maybe it was another NZXT Apollo
@emoners
thank you papi. ;-)
Looking rather plain compared to the rest of you. TO be honest its that baby diarrhea P5B that spoils it.
P180 Black, no sidewindow.
http://www.is-mad.com/upload/userfil...ig_modular.jpg
Here is my CM690 Blue Mod.
http://i238.photobucket.com/albums/f...90BlueMod1.jpg
http://i238.photobucket.com/albums/f...90BlueMod2.jpg
http://i238.photobucket.com/albums/f...90BlueMod7.jpg
http://i238.photobucket.com/albums/f...90BlueMod5.jpg
I still need to do a window mod. But i haven't settled on a design for it yet and i need to order a sheet of Blue transparent Acrylic.
Zalman mod looks awesome :up:
Thanks guys. The top fans are modified to sit just under the mesh. I have a link to the build in my sig.
@lefy, yes its the KAMA METER, got it also in my pc here and its awesome ;)
Well, like a lot of others, I bought a couple of the sale Lian0Li built Rocketfish cases. Wife has one and I have the other. Hers will remain stock....she doesn't really care much about what her computer looks like as long as it works. She got one simply because I was not satisfied with the interior temps in her mid-tower Gigabyte GZ-X1 case, so the Rocketfish provided a lot more breathing space for her quad core system.
On the other hand, I tore mine down to its bare chassis and started off by painting the bare chassis gold. Then I painted everything removed black.
This is what it looks like partially reassembled:
http://jamayer.org/pics/rfcase2.jpg
I purchased a Lian-Li vented, windowed side panel from FrozenCPU......while I've put my own windows into panels many times before, I chose to buy this one because I wanted a spare side panel and because Lian-Li vented the panel. I must say the panel is very well made and as an extra benefit by buying one pre-made by Lian-Li, the window was reinforced along most of its edges with metal supports, giving the panel and window a lot more structural rigidity than most windows have.
http://jamayer.org/pics/panel6.jpg
http://jamayer.org/pics/panel4.jpg
The panel fits like a glove....perfectly! The panel is a Lian-Li part W-75BP.
Unfortunately, the vent is a bit lower than the side mounted exhaust fan....I guess because the cases the panel was originally intended for had two power supply options...top and bottom. The Rocketfish case, on the other hand, has the top power supply option removed and some of the space the upper power supply would fit in transferred to between the top of the bottom mounted power supply and the bottom of the motherboard's slots. Oh well, cannot have everything.
Going to use a Kikbox grille to mount my TC rad up top......it's one of the rare grilles that actually fit TC radiators....and is a very open grille to boot.
http://jamayer.org/pics/grill4.jpg
The slots for the outer two fans give the grille the ability to fit both TC rads and rads that use "normal" fan spacing like Swiftech and HWLabs.
Hello guys, I am Elian fron Rosario, Argentina i'm new at the forum so i want to share with you my case
The case is an old school Thermaltake WinGo
http://img179.imageshack.us/img179/1...bs18db7.th.jpg http://img123.imageshack.us/img123/8...bs12zr4.th.jpg http://img411.imageshack.us/img411/4...sizedc0.th.jpg http://img411.imageshack.us/img411/3...sizees8.th.jpg http://img411.imageshack.us/img411/9...sizepo4.th.jpg http://img262.imageshack.us/img262/1...sizeej1.th.jpg
http://img262.imageshack.us/img262/1...sizemi2.th.jpg http://img341.imageshack.us/img341/3...sizepc0.th.jpg http://img184.imageshack.us/img184/1...sizepr7.th.jpg http://img184.imageshack.us/img184/5...sizevh6.th.jpg http://img508.imageshack.us/img508/1...sizeic0.th.jpg http://img508.imageshack.us/img508/3...sizemb9.th.jpg http://img508.imageshack.us/img508/8...sizeiz0.th.jpg http://img266.imageshack.us/img266/3...sizedm8.th.jpg http://img266.imageshack.us/img266/2...sizerk0.th.jpg
I hope you like it, its nothing compared to the terrible rigs I've seen here, but i love it
That's a cool case and really nice cable management man. Welcome to XS.
Nice looking case, Elian_BHZ. I'm really liking the quality interior paint job and radioactive symbols. ;)
Well photographed, as well.
Thanks fella, i love how is it looks mat black painted !! I used to have more uv stickers but it seemed like a circus jaja
Soon i will be taking more photographs with new modifications i did to de case, specially to de hard disk drive caje system !! now i have a better air circulation
And i tell you that i am a pictures fan ! i love photography !! i use to take hundred of them !! specially of my case !!
Metallica action figures?! AWESOME!
Yup, my half-bro gave them to me.
:yepp: :cool:
Baron have you not got the floppy power connector connected near the gfx card?
My comp the pics are a lil bad but ehh
