nope..unlikely. As said...those are both pcie x 16 slots.
edit:
14970 3dmarks 06 on PCIE1
14970 3dmarks 06 on PCIE3
So..same performance!
thanks!!! ive been looking for something like that
my fsb is 442, and my strap is 333/800 , cpu multi at x8 ... so that gives 3.537ghz cpu and 1061mhz memory... i keep my memory at 5-5-5-18 and everything in the clock fine delay as more aggressive , then set the dividers to keep the ram at slightly above 1000mhz ... is there a better way?
its a try and error thing, depending how much your hardware can handle. Some dividers my board here doesnt like at all. I am also at 3537 right now, anything higher and i might need WAY more volts. Ram doesnt go too high either here.
Very often my comp don't wanna start after night - fans spining and that's all - there is no signal, nothing, I have to restet comp and then it's working fine.
I had the same on Abit IP35.
Any ideas?
i know you guys have run benchmarks and all so i want to ask you...
what gives better performance, tight ram timings and low fsb or dividers, or high memory mhz with loose timings?
Do you mean mem freq? because FSB and Timings are unrelated. The optimal thing is to have high freq with low timings, but at a certain point if your freq goes high and the timings follow, it doesnt improve performance. The key here is a correct balance between the two and you need to find that by raising the mem freq and seeing where you start to lose performance. Then work down from that mem freq. and work on your timings. ;)
Is this after a total shutdown? Standby? Hibernate?
Have you tried another PSU and seen how that psu reacts to the same situation? I find it near impossible to believe that two boards from two different manufacturers and different chipsets could have the exact same problem. :)
there was a very good comparison on some site..i think it was on an OCZ site where they did such comparisons.
As far as i remember...CPU speed, then mem speed
Some very few theoretical applications preferred a litle lower mem speeds but at tight timings, but for overall and real life performance more mem speed is better even at lose timings - so 500 mhz at 5.5.5.15 would be better than 440 4.4.4.12 (just as an example)
My e8400 Q750A031 seems to be a bad batch :mad:
But it´s always core #0 that is unstable and core #1 that is stable. So could the GTL REF voltages help core #1 or some other settings?
1/11 Bios Changes are in RED and the rest are default
Any suggestions are welcomeCode:PC Health Status
Adjust CPU Temp: +15 and it´s still ~3 degrees under coretemp during load
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled none of the others is needed right?
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 9x
- Target CPU Clock: 3996
CPU N/2 Ratio: Enabled
CPU Clock: 444
Boot Up Clock: AUTO
DRAM Speed: 333/667
- Target DRAM Speed: 889
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.4375v CPU-Z 1.456V No more is suggested for 24/7 am I right?
CPU VID Special Add: AUTO
DRAM Voltage Control: 2.10v
SB Core/CPU PLL Voltage: 1.51
NB Core Voltage: 1.504
CPU VTT Voltage: 1.100
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting:
- Enhance Addressing:
- T2 Dispatch: Enabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: AUTO
- DIMM 1 Clock fine delay: Current
- DIMM 2 Clock fine delay: Curren
- DIMM 1 Control fine delay: Current
- DIMM 2 Control fine delay: Current
- Ch 1 Command fine delay: Current
Ch2 Clock Crossing Setting: AUTO
- DIMM 3 Clock fine delay: Current
- DIMM 4 Clock fine delay: Current
- DIMM 3 Control fine delay: Current
- DIMM 4 Control fine delay: Current
- Ch 2 Command fine delay: Current
Ch1Ch2 CommonClock Setting: AUTO
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 18
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): 54 as suggested by OCZ for my memory
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: AUTO
- Channel 1 Phase 1 Pull-In: AUTO
- Channel 1 Phase 2 Pull-In: AUTO
- Channel 1 Phase 3 Pull-In: AUTO
- Channel 1 Phase 4 Pull-In: AUTO
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): 4
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): 4
ALL PRE to Refresh: AUTO
edit: my signature doesn´t seem to show up for some reason so here are the specs
E8400 Q750A031
DFI Lanparty LT X38-T2R
4GB OCZ DDR2-1000 XTC Platinum
BFG GeForce 8800GTS OC 512MB
PC Power & Cooling Silencer 750W Quad
Thermalright Ultra 120 Extreme
Thermalright HR-03 GT
well my board is only happiest when on 69%gtl settings
n loves my ballistix over 1200mhz 2.09v
she even loves 500fsb
By that do you mean you use 69 on all three settings? Iow
x CPU GTL1/3 REF Volt: 69
x CPU GTL 0/2 REF Volt: 69
x North Bridge GTL REF Volt: 69
I can get fully Orthos stable with 1.4V at 3906 (9x434) (1:1) but need to bump it to 1.4375V if I want to run 5:6 (1042). So do you think GTL settings could get me to 4GHz?
edit: your sig says e6850 or doesn´t that make a diffrence? can the new 45nm cpu:s take the same gtl voltages?
no thats not the same as teh % the gtl on this board is a number so u have to find 69% on your own, so if ur at 1.4V then u need 96/94 for the cpu gtl
my first inclination is the same as "Russian", your PSU might be the culprit...BUT...i did have cold and warm post problems on this board...it was intermittent...a guy suggested increasing the NB voltage and when i put it up in the 1.65v range it stopped and posted everytime...just a suggestion.
OK, guys, I finally got around to installing the mobo and CPU this weekend. Decided to add Vista to the mix as well, but I have a small problem. I can't get the audio driver to load. The Device Manager shows HDMI audio, which is the one from the 3870X2. When I manually try to install the audio drivers, I get the yellow exclamation mark in the Device Manager and it says the device cannot start. If I click on "find solutions," nothing comes up.
I tried to install from the driver CD and the DL file on the DFI website. I get 6 or 8 entries to choose from when I install the device manually. Anybody else have this?? :confused:
