PRODUCTS: DX38BT, DX48BT2 (Standard BIOS)
BIOS Version 2000
About This Release:
• July 01, 2009
• BTX3810J.86A.2000.2009.0701.1128
• SATA RAID info:
Intel(R) RAID for SATA – v8.9.0.1023
• SATA AHCI info:
Version UPSD src 12-03-2007 for ICH9
• PXE Nahum info:
Intel(R) Boot Agent GE v2.09.00.02
New Fixes/Features:
• Fixed issue with INT15h E820h reporting overlapped memory ranges.
• Updated RAID option ROM: Intel(R) RAID for SATA - v8.9.0.1023.
• Fixed issue where SMBIOS Type 10 (On Board Devices Information)
structure for On-board LAN "Description" field is incorrect when
On-board LAN is disabled.
• Fixed issue where SMBIOS Processor structure shows incorrect CPU
types.
• Fixed issue where SMRR valid bit is not set.
• Fixed issue where VA option is not grayed out after supervisor
password is set.
• Fixed potential intermittent S3 failure.
• Added security changes.
• Added the Downgrade password security check.
• Changed HPET setting to default enabled.
• Added Fault Tolerant Firmware ID solution.
• Fixed string for “Intel® 64 Architecture Capable”.
• Updated support for high power PCIe adapters.
John
