Originally Posted by fhpchris
Go look at my last posts, they tell everyone the problems that are easily advoided. Buying crappy ram (OCZ Gold =/= micron) is on the list.
Even with your amazingly crappy TEC on air cooler, im sure the NB is just getting pushed too hard, because your running stock cooling on it. Again, look at the list of problems about this board. This isnt complicated.
TECs on air do not work well on any cpus, let alone cpus that can pull 200+ watts, your crappy little air cooler just isnt powerful enough to dissipate 300 watts of power here...
Crappy ram on a bios that runs tight timings = bad. There are alot more alphpas than what the bios shows you, you coulda gone and looked though memset instead of crying about it here, or you coulda just bought micron and not PC-8000 crap ram.
You do not understand:
THIS BOARD WORKS FINE, ONLY YOU ARE NOT USING IT PROPERLY.
1) throw the TEC AWAY!, get a real air cooler like the Tower 120.
2) Get a NB cooler
3) get RAM that isnt crap, or at least run memset.
4) run 18*200 @ 1:1, no more ram issues. When you get to be a better overclocker, you can try something like 333*11 or 333*12
Ive only been posting this for like 20 pages, how about you go listen.
