Download LATEST BIOS & DRivers prior setting up your system
Downloading and installing latest BIOS & Drivers helps reducing installation problems and instability of your system. Don't use the drivers on the accompanied ASUS CD of your P5W HD Deluxe motherboard!!
Please note:
NEW FINAL Intel Matrix Storage Manager v.6.2.0.2002 dated Oct 13, 2006 available
See link:
http://vip.asus.com/forum/view.aspx?...Language=en-us
My first attempt.....after a lot of reading these forums!
This is my first shot at overclocking:
http://www.ihssol.com/MY%20PC.JPG
verification is here
My voltages seem low but the system is stable. Going to get a phase change unit from jinu117
next and see how hard I can push it.
F.E.A.R. with max settings is a real treat on this system! I bought the Dell 24" widescreen and it is AWESOME. No dead pixels and 1920x1200 rez....SWEET!
Thanks in advance PHOGGER for saving me all the typing!!
BIOS 1506
BIOS SETTINGS
JumperFree Configuration
AI Overclocking set to: MANUAL
CPU Frequency : 400MhZ
DRAMM Frequency :800Mhz
Performance Mode :Standard
PCI Express Frequency : 100Mhz
PCI Clock Sync Mode : 33.33Mhz
Memory Voltage : 2.20v
CPU Vcore Voltage : 1.425v (drops to 1.40 under full load)
FSB Termination V : 1.40v
MCH Chipset V : 1.55V
ICH Chipset V : 1.05v
Digital Home: Disabled
CPU Configuration
Modify Ratio Support : Disabled
****Ratio CMOS Setting: [9]
Microcode Update : Enabled
Max CPUID Value Limit : Disabled
Execute Disable Function : Disabled
Enhanced C1 Control: Disabled
CPU Internal Thermal Control : Disabled
Virtualization Technology : Disabled
Intel SpeedStep Technology : Disabled
Advanced Chipset Settings (DDR2)
Configure DRAM Timing By SPD : Enable
DRAM CAS Latency : 4
DRAM RAS Precharge : 4
DRAM RAS To CAS Delay : 4
DRAM RAS Activate to Precharge Delay : 12
DRAM Write Recovery Time : 16
Hyper Path 3 : Disabled
DRAM Throttling : Disable
Memory Remap Feature: Disabled
Intel TAT 42/45C Ambient 70F
