just to let you guys know...
www.scan.co.uk has 146's in and they are almost confirmed to be CABYE
Hmm what would clock better though... 144 CAB2E's or 146 CABYE'S?
Where're you getting the CAB2E? I've not heard of this particular stepping, but then again I've been a bit out of the loop...Quote:
Originally Posted by Richdog
CPUCITY... i've just heard that the CAB2E stepping has the revised memory controller as seen in the new FX-57's... can anyone confirm that?
Awesome...I'll be getting mine tomorrow, then. :DQuote:
Hmm I may order a 146 CABYE from scan as well, as they have those in too apparently.
Ahhh my wallet is screwed. :(
there is a spot where there is no silicone. this is where i put the blade in and went all the way around :toast:Quote:
Originally Posted by 5days
just stop if you feel any SUDDEN resistance, you hit one of those little chips ;)
also, looks like i've gotta try to find a CAB2E now :p:
We all know that it's not possible to translate AMD's TDP into real world numbers. First of all, AMD stress them in a very hard way, more than Intel. But that's not all, since the introduction of K8 there has been some TDP's that are just to high and way off. You could think that the extra high numbers are a reservation for forthcoming faster models, but that's not always the case.Quote:
Originally Posted by Kameleon
For instance, a 3000+ Oakville (2 GHz, 512 kb, 1.35 V) have TDP = 35 W, and a 3500+ Winchester (2.2 GHz, 512 kb, 1.4 V) have TDP = 67 W. 200 MHz and 0.05 V nearly doubles the TDP, WTF? This is just one example. Different sites have measured the power draw and showed that the 67 W figure is not only high like all AMD TDP's, but totally wrong. The mobiles often show the real TDP, but remember that even those are AMD numbers that cannot be reproduced.
Start with that Oakville and recalculate the TDP using 3500+D data >> TDP = 41.4 W. That's pretty low, and still supposedly higher than real world! Now compare to data from lostcircuits and SPCR.
Lostciruits tells us that the 3500+D uses 31.6 W, and a 3800+E 30.8 W.
SPCR on the other hand says it uses 4 A on the 12 V 2 line, which equals 48 W, but that's including the PWM on the mobo which have an efficency of maybe 85% max. Anyway, it's hard to get beyond 40 W stock no matter how you look at it.
But, don't forget that there are three different types of CPU's out there.
Low power T64, regular K8 (including many A64, all S64, and some Opterons), and power hungry FX (and some Opterons, like CABNE). My example was about the regular ones.
A San Diego 2.8 GHz should need something like 60 - 70 W.
Who cares about TDP if it's nowhere close to real world numbers?
Quick questions re: Skinning an Opty:
I read about the raised portion of the socket interfering with the contact between sink and chip.
Is this true for ALL sinks which don't have a cutout for the socket?
I have a NexXxos CPU block which is perfectly flat :(
Hi all! I have an X2 3800+ as you can see in the signature...Do you think it wolud be better if I get an Opteron (single or dual core) for gaming?...I`m happy with my X2 but I think can get sth more in OC and games with an Opteron...or am I wrong? I can sell my X2 and go for an opty for this money...or should I stay with my X2? I need the computer mostly for gameing...
Regards,
Primoz
The Opterons have a really good memory controller i think.
My OCZ EBs did nearly finished the 300MHz
1M goes up to 303-305MHz.
http://mitglied.lycos.de/freestylerc...cz@297@32M.JPG
http://mitglied.lycos.de/freestylerc...primeblend.JPG
free
^ What stepping?
Well I've now had in the last two weeks:
Opty 148 cabye from Komplett - does 3.0ghz with 1.65v - sold already
Opty 146 cabge from cpu city - does 2.8Ghz with 1.6v - sold already
(another) Opty 148 cabye from Komplett - does 3.0ghz with 1.6v
Opty 144 cabne from computersmsa - does 3.0ghz with 1.6v - sold already
So I've just got a single 148 3Ghz left now, but after seeing the new 146 batches seem to be cabye I have ordered today:
Opty 146 - from Scan - already in stock, and a 146 from Komplett - in stock at supplier, wait 5 days. Plan is to hope I get a 3Ghz capable 146 out of those two, then sell the other 146 and the 148 and make some cash back.
"My name is Nick, and I have an addiction to buying computer parts..."
Nick
Yes CAB2E is most definitely a FX57 stepping. If it's the CAB2E 0531RPMW, then you have found gold my friend.Quote:
Hmm no... they're 144 CAB2E 0540 FPMW.Quote:
Originally Posted by xenolith
So I may have hit bronze ofr silver instead heh.
At least I have a CABYE 0540 FPMW coming and I KNOW they're the shizz from the results i'Ve seen that dmx etc posted. :)
im wating - celsius and still my computer is in my room no open windows or anything else and now my room temp is around 23c. There is new my personal record with zalman 7700 + ystech 120x120 125cfm :)
so maybe im lucky when i got this cabge its pretty one... and oh well more to come... :fact:
other thing in my rig DFI NF4 UT AND KHX3000 2x256mb sticks :D
http://img374.imageshack.us/img374/6...iesp8m71jp.png
0530 APMWQuote:
free
Still an FX57 stepping nonetheless. It probably will perform as well as the CABNE's.Quote:
Maybe this is things to come. Maybe the new US shipments will be CAB2E steppings. :slobber:
Maybe you're right, i hope they do perform as good. I googled the stepping and received not one hit... so I guess it is absolutely brand spanking new. :)
Yeah, same here. Have yours been sent yet? Got my despatch confirmation this afternoon, SO EXCITED :DQuote:
Yup... got that about 30 mins after I ordered. Will be here tpommorrow morn I expect.
To be honest though i'm more looking forward to the 146 CABYE 0540. :)
1 suicide shot of my 144 CABNE 0540.
http://valid.x86-secret.com/cache/47276.png
This is not an issue here , I have taken then IHS of my Opteron and I'm also using the Nexxos block. All works good, gained 5-7C on load temp and helped stabilize my 3ghz o'clock.Quote:
Originally Posted by Jimbo Mahoney
Just received my 144
OSA144DAA5BN
CABNE 0540APMW
1337AJ507xx
Looks like my CPU is also leet :) People cover the serial number in case of warranty right? Either way I have an incredible high batch, number, but still have high hopes. THis CPU is 1337! :D
Setting up water, hope to have first runs in tomorrow.
lol what voltage did you use there?Quote:
Originally Posted by Pt1t
