I found this thread to raise vcore to 1.644v a while back when I was pinmodding my laptop:
Thread:
http://www.xtremesystems.org/forums/...t=63514&page=1
Photo of Pinmod -- Ignore the horizontal jumper - that's what raises the FSB of 400MHz dothans to 533MHz. The three vertical jumpers on the upper-left portion of the chip are the ones you want:
http://img226.echo.cx/my.php?image=pinmodphoto2zm.jpg
I'm a newbie so I'm not sure what the advantages/disadvantages doing this pinmod has compared to the motherboard vcore mod, but I would like to know. Maybe some of the pros can answer that one :D
Something I just thought of -- you probably have to start with a lower vcore bios setting if you do the pinmod. I'm pretty sure that jumping the pins bypasses the bios settings. I would set it back to the default 1.340v in the bios to start.
