like i said it happens lol
you think its stable but not really lol bump nb voltage to 1.4
Hi,
I strongly need some advise here..
My computer have went into an "endless boot" and I cant find out how to solve it. Some times when I clear cmos can I enter bios once but right after I get this post code 88 and the endless boot has begin again.
I have swaped memorys and tryed different slots, disconnect HDs and all fans. Removed PCI cards. I have even removed battery during night and clear cmos with out any success.
Is this a case for a RMA or can I try anything else?? All leds are ok on board and I can not see any damages. The board has always work well before.
Thanks in advance.
on any successful boot, can you try reflashing with the latest official bios?
if this doesn't work, I would RMA the board
your bios may be somehow corrupted.
but the best thing is to RMA it
nice same configuration -__-":
714:
http://img204.imageshack.us/img204/6...ine4rz0.th.jpghttp://img527.imageshack.us/img527/2...ine5vp6.th.jpghttp://img520.imageshack.us/img520/9...ine6zg8.th.jpg
725:
http://img150.imageshack.us/img150/7...ine2co8.th.jpghttp://img213.imageshack.us/img213/2...ine3ji9.th.jpghttp://img243.imageshack.us/img243/9...ginepg3.th.jpg
got it. wouldn't boot from the green ports (Ich9) had to use the yellow
Anyone else having problems with Bernstein audio module? im using s/pdif coax and the sound is breaking up at random interval. Like when im listening mp3 and then all the sudden it is silent for 1s and then the music is playing again.
I haven't used spdif output but I never had any problem with realtek soundchips.
Try latest drivers from here
http://www.realtek.com.tw/Downloads/...&GetDown=false
Another stupid question for you guys.
What is the main difference between the UT and LT of the DFI X48? is it just cooling?
@freaksavior
yeap :)
So your paying another $50 just for the heat pipes? the bios and layouts are the complete same?
if that's the case DAMN im glad i didnt get the ut.
I had bought it from the egg for $310 and then found the lt for $220 so saved myself $90 all because of heatpipes :rofl:
u pay more for a worse cooling solution, i dont get it
the tower cools awesome and im drooping an mcw30 on there and i dont have to cut adn salvage the pwm cooling its the greatest cooling ive had in years
just found out that dfi forgot to pay for their fan/support forum :p
http://host.dficlub.org/suspended.page/
No dout this will be a retarted question:ROTF: I did a reformat today and ran the chipset software off the DFI driver install disk and in device mgr it says i have a x35 chipset:confused: So i looked up x35 chipset on intel site and it says it supports DDR3:confused: What is up with that:confused:
RMA it. I mean it too.
I experienced the same thing little over a week ago after my rebuild with my x48. If left the battery out all night and then reset the CMOS, I would be able to get into the BIOS but after a few mintues.. more lockups. I tried switching everything and finally decided the board somehow conked out. I'm still waiting on my RMA. :(
As for reference, I got post codes 01|25|75|88|89
During prime small FFts priming my Q6600 @ 4.0ghz the Pwn becomes in the high 60c. I know that the PWM are getting hot always, but is there any reason to concern about it? I did reseated the heatsink with MX-2 but a Very thin layer, and i got a 70/15 fan( stock AMD delta fan) blowing against it.
will reseat it with thicker layer , thnx zsamz,
Another prob:
everytime when it fails I @ prime /reboots during prime I look @ smart guardian at the same time the vdiMM jumps up to 3.42V O_O and 5V rail drops to 2/3V , is this a well known problem with smart guadian or my board is really producing such volts and either my board or my PSU is flaked:X
