Am i just lucky or do i have a golden board?
Hi guys,
I have a SIIE, actually its my fourth but anyway. Now i continue to read about all the problems and difficulties to get the board stabile.
But since i got the last RMA i can easely set the FSB to 460MHz with the timings at 7-6-6-16 CR1 (Using 2GB Corsairs, 2.00V). If i use my OCz 2x2GB 1600EB i can go to about 1810MHz 8-7-7-20 CR2(1,92V) before it goes :banana:
The CPU is at 4370MHz for 24/7(bench tested @4,6-4,7GHz). Everything is Prime, OCCT and 3DM stabile. Well to be honest i´ve just run prime for 8h(how long do one need to run prime before the system can be considerd stabile?).
Now i do have some difficulties to push the FSB higher. If i do the board needs to be reset. So 460 is the current stabile maximum that i´ve reached.
The rig is the one in my Sig.
LLC enabled
My CPU likes voltages...
CPU 1,49V (It is high but still the temps under prime max out at 51C, so its rather fine i guess)
PLL 1,6
VTT 1,3
NB 1,68
SB 1,55
0 -29
1 -24
2 -24
3 -29
NB ref +30
P1-P1 Enabled
VDIMM 2,00V (For my corsairs)
What do you guys think of this? And do you have any ideas how to go beyond FSB 460Mhz?
Cheers friends:wave:
