dfi x38 can't select straps themselves - what divider you use determines the strap you use.. not sure which one is used at 1:1 sounds like 266FSB strap ???
what settings you using ? template at http://i4memory.com/showthread.php?p=86150#post86150
if you set clock fine delay manually on other dividers, you need to use different clock fine delay values when you change dividers. So set them all to current value for clock fine delay, and then power down system/power off psu. Then turn back on and boot up at 1:1 will have different clock fine delay current values. Start at a lower stable 1:1 clock i.e. 480FSB or 490FSB and take notes of the current values as per http://i4memory.com/showthread.php?t=4743.
I find with E8xxx on DFI X38 at higher FSB and mem clocks, you need to be tuning the clock fine delay values in conjunction with tuning GTL ref volt values + CPU VTT. Errors and/or freezes in memtest86+ v2.00 when using E8xxx can be related to either or both incorrect clock fine delay values and/or incorrect GTL Ref + CPU VTT combinations.
Very tricky with E8xxx on DFI X38 to get fully stable at certain FSB/Mem combinations. Some combinations I luckily dialled in right settings for stability some combinations tried days to get right with no improvement heh.
It's a fine art hehe
