hmm... http://valid.x86-secret.com/show_oc.php?id=371240 @ 1.62V @ SingleStage
Should there be more possible with more vcore ? I think so....because 1.62 volts isnt real sick. The key is 1.8 volts for the san diegos.
I see you're talking about our processor.
But it's my first post here, so i want to say Hello!
This san diego is: KAB1E 0619XPMW.
Just tested on our new mobo - Dfi lp ultra-d (till now we made it on Dfi rdx200), but now we have some problems with cooling...
Our singlestage is weak, and doing idle -22*
tell me, is it normal, ihs are straight:
- venice 3000+ e3 @ 3303mhz @ 1.82V we have in core temp ~ -7*
- san diego 3700+ e4 @ 36XXmhz @ 1.62V and +14*
btw: best spi 1M (on RDX): 24.578s @ 3365mhz, mem @ 280mhz 2-2-2-5:
http://images34.fotosik.pl/255/a55c194ec65b9d8em.png
gianni-gt, stunned_guy and knopflerbruce respect for great job which You are doing with s939 :)
regards Martin & Lukas
Thanks guy ;)
I also have one single stage that will do some times -43c...normal is still -36c.
Core temp shows some mess sometimes so dont doubt it all time.
KAB1E is very cold bugged but this 0619 XPMW is very good. I heard about that stepping that will does 3 ghz prime @ default vcore and higher with air cooling. So its no problem to go higher than 3.5 ghz.
It seems that your problem is the heat spreader ---> it has not 100 percent contact to the DIE. Help: you could remove the hs for better temps. Or you could take dry ice for cooling.
Than you can take more votage and 3.7 ghz and higher should no problem ;)
For superpi take 2x512 mb and your time will be better.
But nice for your first try.
another good xpmw... in the past we've had the chance to buy one of these, but it was too expensive. but i think my wr is safe.
We never bought such 0619 XPMW why ever ? I should search after that :D
3800+ Newcastle on way to me.
opty 146 in the house!!:D
CABYE 0540FPAW, #093:)
Hope it's a good one. 3g @ 1.4v would be nice, as breaking 3.8 with 10x-multi is pretty hard...:rolleyes:
hey knut, that opty 242 AAADB was my :(
and this was on ebay, but i have not money for that
http://i8.ebayimg.com/03/i/000/f5/12/26a1_1.JPG
made 02 23 (july 2002 approximately) :clap:
wow. those are with ceramic package :eek:
I have here 1 Opteron 252 with ceramique package....and without hs. I will sell this cpu now.
i think that was the cpu from the system that never runned :D
btw:
http://www.ripping.org/img/cpuz_warning.jpg
How's this Opty 170?
CCBWE 0551UPMW
@ Turrican
Yes its socket 940...but i will sell this system that never runned :(
@ gianni
I saw that warning in our database :D
Sorry knut but my 3000+ venice is still in my hands :D I will never sell this chip.
this cpu isnt good under single stage and prime...only 2.6 ghz with default vcore and prime....
The step of that opteron 242 with ceramique package is CAATC 0420MPMW, its an OSA242CEP5AL....its not an 252 :D My fault.
I also have one OSA252FAA5BL CABHE 0448MPMW here. this is an 252 with green package.
Hehe, I didn't want to buy it (well, I want that too, but it's not the reason I asked:D) - I just wanted to compare it to my 3200+ 0602APAW. I think your chip did 2.8 @ 1.41v (at least a 3000+ 0602APAW at forumdeluxx did that). My chip did about the same. Vcore went from 1.39-1.41v all the time, temps slightly below 40c. Didn't test it for ages, was just a quick air run to see if it worked or not:) But if it's got the same coldbug as your 3000+ it MAY be a gianni-killer:D
nice man, oldschool overclocking at its best
hmm...i do have an a8n-sli deluxe and a few 939s laying around :)
I tested my 3000+ yesterday again but the cpu is dead :( I wonder how this was done ? So no one will break that record I think.
Sorry to hear that. I also had a 3000+ 0602APAW, but it was DOA:mad: So no idea how great it was.
But yeah, that 3000+ Venice WR is perhaps the hardest one to break. Except for the 4000+ SD record, maybe.
I have an SLI-DR on the way, btw. And a chiller:) Maybe I can do some semi-serious benching in a couple of weeks time... Depends on alot of stuff, though, but I'm tired of not being able to max out all the CPUs I keep getting. Must have like 30 CPUs that wait for dryice. With the chips that weren't maxed out under dice, it'll be close to 40 on Ln2:D Not counting the 15 CPUs I expect to get from the US pretty soon:p:
oh stuned that's bad... but that's happend to a lot of mine cpus also... used under subzero, doesn't use it a couple of weeks, remounted => dead... i think the cpus was boored to death :D
I think so also ;)
Knut, you are crazy !!!! :D
My time on socket 939 is also coming to an end....i sell almost all of my hardware to do some new things. but one setup with single stage and sli-d i will not sell to do here and here some good socket 939 action.
