Originally Posted by JokerCPoC
Has anyone noticed in Everest that the 1st two cores of a QX6700 will run at the desired multiplier(12 in My case) and that the other two are at the default multi of 10?
The settings after I updated the Bios from 13F to 14B1 were reset to defaults already and I had to set them from My memory.
I ask as I just updated My Bios to 14 B01(1.4?) and I thought this problem was supposed to cure this?
Oh and Everest and the latest Beta of Speedfan 4.32 read the cpu temps as about 20-25C too high for the cpu, the cores read about 15C higher than the cpu in Everest(58C currently, It's been as high as 65C, It's false as My other QX6700 cpu reads a Temp of 31-38C in an Asus P5W DHD(Everest says more like 70-75C for the cores and 100C for the cpu, Go figure, even at 3.38GHz), The Vigor Monsoon II TEC cpu cooler panel in either PC says 37C and 43C respectively), It would be nice If this were fixed. I tried running the uGURU software and It read the same temps and then proceeded to shut down the PC thinkin the cpu was overheating, I had to go into safe mode and uninstall It and erase the install file.
Oh and I wish that the 1333 strap would do 2:3 or something that will allow My ram to not exceed 442MHz and the cpu to work at 3540MHz, 800MHz strap is being used right now with a 2:3 ratio as My ram can do that with a multiplier of 12. :D My ram is OCZ Gold PC2-8000 with timing of 4-4-4-10(stock is 5-6-6-15).
