Yup, mine is exactly the same, about .02 (in win) under what is set in the bios.
1.45v=1.41v in windows.
mine is ~0.04
set 1,35 in windows it is 1,3
There is no indication that the offset is constant. or for that matter that it is linear or predictably exponential.Quote:
Originally Posted by Punkas
Without comparing the same CPU and cooling at different temperatures you cannot just go in and say "15 degrees off all the time".
DFI NF4 (nonexpert) motherboards pretty much always display that much lower.
For idle you get what you set in the BIOS.
For busy you get 0.025 V higher, and that is without any change in the sensors report. That sensor must sit in front of whatever unit raises the voltage on load.
whats your lowest Vcore @default clocks?
greetz
Not bad.. much better than my 0550 UPMW (ran way tooo hot). Time to remove IHS and get a 0551 UPMW.
CCBWE 0551 VPMW 300x9 = 2700 w/1.40v + 104%
Attachment 43117
who is that in the background?Quote:
Originally Posted by bmac11
Brooke Burke :slobber:
Can't get my Patriot 4800 to run 1t @ 250 :( Time for a 2gb kit then.
seems to me after reading through this thread that the 165's & 170's are the highest overclockers out there....so if you were going to buy one which would it be?
To say they are the highest clocking is somewhat incorrect. To say they are the most popular is more on the mark. Anything above a 170 just isnt a very good value. To answer your question, it really depends on how much you want to spend. They both pretty much overclock the same give or take 100mhz.Quote:
Originally Posted by Grinch
Vote for 170 ad above for x10 multi...165 with x9 multi have slimmer chance to get more than 2700mhz:fact:Quote:
It also depends on the stepping ... I have 2 sealed unopened retail 165 0550 UPMWs and someone offered me $1,000 for them
And you still have them? :stick:Quote:
Originally Posted by Kaiser_Sose
Yes and they are still sealed
Hey, I am to get Opty 170 thru my relatives in NJ. Which are the recent stepping doing good? Also has anyone come across 06XX 170/175? Thanks in advance.
I got a Opteron 165 now:
Its a CCB1E 0550 VPMW if i remember correctly.
I can run 2600 MHz @ 1.35v Dual prime stable for more than 9.30 hours. But is stopped the testing @ that point.
I can do 2690 MHz @ 1.43-1.44v. ( Max of My A8R-MVP :slapass: )
Cooling air: Zalman 9500.
My Asus A8R is realy holding me back. Venice could only get 1.52v. So i need a new RD580 board fast.
Abit AT8 X32 or a DFi. No More asus for me :nono:
i have seen a 4400+ X2 CCB2E 0553 cpu's go 2800 MHz @ 1.4v and 2900 @ 1.55 Thats a lot faster than my 165. Also air cooled.
lol:slap:Quote:
Originally Posted by Ender17
:p:
Actually teh 0550UPMW and 0550VPMW are the best Clockers!
PeteX has an 170 CCBWE0550VPMW and his Chip makes under Water
2x3100Mhz Primestable with 1,426Vc wiht HS still on.
well all opterons are = temp sensitive too hot or too cold and they clock poorly... whether a stepping clocks well might need to take into a/c ambient/cooling tempsQuote:
Originally Posted by Rufus7
i'm sure my opterons would clock higher if my room ambient wasn't 29-33C even after 1HP portable air con is running!
chilly European folks have it good ambient wise :)
Yeah Eva 2000 ind Australia is Summer we have Winter Eva 2000!!!!
you are living down under.
In 6 Months it will be changing! You will have Winter and we will have Summer.
But we have Aqua Medic Titan Waterchiller in Europe.lol
Here´s a List with Dualcore Results. always 3hs Dualprime 24.14 Custom FFts in place.
From old germany HWLXX.
Look under the Signature from PeteX he has the Forum record with 2x3100Mhz an 1,456Vc under Watercooling and HS still on.
The Screen is from Pete_X at the beginnig of his Testing yesterday.
http://img442.imageshack.us/my.php?i...45602231mb.jpg
http://www.forumdeluxx.de/forum/showthread.php?t=167156
Luftkühlung=Aircooled
Wasserkühlung= Watercooling
our winter in Australia is like your summer in that part of europe ROFLQuote:
winter is getting warmer in Australia last winter average room ambient was 26C day and 19-23C night :)
2nd time you mentioned aqua medic titan so googled and found what it is http://www.aquatictech.com/chillers.html and wow, do these work out of the box for water cooling ?
Originally Posted by eva2000
yah i googled it too, those look very interesting:hehe:
If you want more you can buy em from NCIX cheap lol.Quote:
My stepping is CCB1E 0550 VPMW L50410. But this aint a wonder core :)
