http://www.funkflix.de/pcseite/3.jpg
http://www.funkflix.de/pcseite/5.jpg
http://www.funkflix.de/pcseite/6.jpg
Nice rig you got there man. IMHO the looks on the CPU block is bleh but I really like the visuals on the NB one.
Usama aka Ferrari Freak
New conroe rig plus added some extra bits and pieces, also a window mod.
http://img.photobucket.com/albums/v608/webbo10/900.jpg
http://img.photobucket.com/albums/v608/webbo10/700.jpg
http://img.photobucket.com/albums/v608/webbo10/100.jpg
Ic3man, is that so big case or u just have micro atx motherboard?
Finally new CCFL's. Sorry for crappy pix.
http://nickfire.com/photo/MYRIG/100_0316.JPG
http://nickfire.com/photo/MYRIG/100_0317.JPG
http://nickfire.com/photo/MYRIG/100_0319.JPG
Nice one there nicks, i like that circle air vent mesh design, did you do that yourself? with what tools?
(i always keep a spare keyboard and mouse handy...)
No, the P180 is not big at all(internally). Its very cramped inside, especially with all the kit I have hooked up. The motherboard is a P5WDH - atx. It took me a good 2 hours to attempt to hide the wiring.Quote:
Originally Posted by L'enFer
I'm new here but just wanted to show my 2 watercooled PC's.
The first one is my old PC, i had that one for a long time but it just could not handle all the new games so i sold it and build a new one.
http://img137.imageshack.us/img137/7378/pc013yr5.th.jpg
Specs of that PC were.
XP-M 2600+@3700+ (200x12.5=2500MHz@1.85 volt)
6800LE@16x1,6vp@375/850 (good for 11k 3dmark03)
The rest does not really matter.
I have got my new PC for about 3 months now and i like it alot. It's a modded Lian-Li PC71. I build this PC for playing all the new games but i wanted it to be very silent.
http://img139.imageshack.us/img139/2...e123bc2.th.jpg
I used 2 Lian-Li covers to build in the fancontroller and to stealth the dvd so it would look better.
http://img214.imageshack.us/img214/8892/dvdew6.th.jpg
I modded the 3x120mm radiator in the case.
http://img157.imageshack.us/img157/9...c004pz2.th.jpg
This last pic is a overview of my complete setup.
http://img146.imageshack.us/img146/3...viewjo5.th.jpg
Here are the specs of my new PC.
Watercooling stuff:
CPU block - Alphacool Nexxos HP Pro Socket 775.
GPU block - Alphacool Nexxos NVXP3 ATI.
Rad - Alphacool Nexxos Xtreme 3.
Pump - Eheim 1048.
Fans - 2x Papst 120mm 4412F/2GLL.
Res - Coolplex 25
Tygon tubing.
And the rest of the hardware:
CPU - Core 2 Duo E6600 2.4GHz@3.1GHz (345x9@1.35 volt)
GPU - Sapphire X1900XT@655/835
MOBO - P5W DH Deluxe.
RAM - 2x 1GB PC6400 DDR2 Corsair
HDD's - 1x 250GB and 1x 300GB SATA2 from Samsung.
PSU - Zalman 460W
DVD - 16x NEC DVD burner.
Fans - 4x 80mm Papst 8412N/2GML. 2x intake and 2 outtake.
I hope you guys like my stuff. If anyone wants more pics or details just ask.
Performance PC's cut the hole, and I bought the FilterRight filter from them too. It was meant to hold a fan, which it did before until I moved my radiator inside of the case. Then I had to dremel down the bolts to size and I just mounted the grille there.Quote:
Originally Posted by septim
what tool did you use to cut the side panel? I'm asking cause I'll be modding mine and I need straight lines :)Quote:
Originally Posted by Ic3man
A jigsaw and a file/dremmel to smooth it out.Quote:
Originally Posted by marauder16
Looks like nobodys has yet complimented you on this Rig...PilatuS... Nice Job! I like the Dual Monitor ;) You watercooling Gear could be better but overall it's a Pretty Good Gaming Rig!
Oh and I like how you clean cutted the holes for the Rad! Looks Professional not like mine...lol
Yeah PilatuS, that looks quiet and damn nice!
Gratz
Tnx for the compliments. It took me about 20 hours just to cut the holes, mount the radiator, the reservoir and the pump. I cut all the holes by hand to get the best result. I really needed it to be good because of the price of the case.
I know that there are better watercooling block and rads but i chose Alphacool because i really like how it looks.
That's Cool! What you do you mean by hand ? what tool did you used to make the job ?Quote:
Originally Posted by PilatuS
I know the name of the tool i used in dutch but not in english so here's i pic of it. http://www.stock-vermeersch.com/cata...umb/027564.jpg
It did cost me about 25 saws to complete the job with that tool.
@PilatuS you have much more patience than I
Nice Job
Nicks, clean rig, very nice.
Nice setup PilatuS, you could do with taking out the 90 degree elbows. I really like the little figurines in your case, very unique, and I love the class look of the Lian Li in the pic of the rad grills. Very nice job.
Pilatus: how bout removing the cover and changing thermal paste on your nb and sb sinks?
<3 Lian Li <3
Heres a nice pic. :)
http://upload.nickfire.com//files/1/...28Large%29.JPG
/\ Very Nice :D
Thanks man. It's mah baby. :D
NickS, Your tubing is realy exciting me! it looks sooo thick :)
1/2" ID, 13/16" OD Masterkleer with a 5/32" Wall! :D
Heres some more pix for you.
http://xtremesystems.org/forums/atta...3&d=1160374333
http://xtremesystems.org/forums/atta...4&d=1160374333
