Did you go back to F7 to confirm?
i go back to F8f and i pass more time of prime lower volts, i go to F8 and same as F3 cant find a middle point like good old LLC1...
thanks guys i think GIGABYTE needs to check this bios as they incoporated nice things loads faster but needs some work on them
flashed to F4a and locked up on loop 12 of prime pfffffff if not a good bios will go back to B2 F8f this is kinda frustrating
this one mate :up:
http://www.fileden.com/files/2009/12...7aud7.f8f1.zip
thanks
please tell me what i'm doin wrong
i cant do nothin with the board
i did boot 100x52 to windows on f7x 1 time
i'm close to takin board out n rma this b2 board
Code:
### MB Intelligent Tweaker ###
Advanced Frequency Settings:
CPU Clock Ratio .......................................[ 50
> Advanced CPU Core Features
Real Time Ratio Changes In OS .........................[ Disabled
Intel(R) Turbo Boost Tech .............................[ Disabled
Turbo Ratio (Core 1)...................................[ Auto
Turbo Ratio (Core 2)...................................[ Auto
Turbo Ratio (Core 3)...................................[ Auto
Turbo Ratio (Core 4)...................................[ Auto
Turbo Power Limit (Watts)..............................[ 1000
Turbo Current Limit (Amps).............................[ 500
CPU Cores Enabled ............................ ........[ All
CPU Enhanced Halt (C1E) ...............................[ Disabled
C3/C6 State Support ...................................[ Disabled
CPU Thermal Monitor ...................................[ Disabled
CPU EIST Function .....................................[ Disabled
Bi-Directional PROCHOT ................................[ Disabled
Spread Spectrum .......................................[ Enabled
BCLK/DMI/PEG Clock Control ............................[ Enabled
BCLK/DMI/PEG Frequency Control ........................[ 100
System Memory Multiplier (SPD) ........................[ 21.33
Advanced Memory Settings:
Performance Enhance ...................................[ Standard
DRAM Timing Selectable (SPD) ..........................[ Quick
Channel Interleaving A Rank A. ........................[ Auto
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................................[ 9
tRCD ..................................................[ 9
tRP ...................................................[ 9
tRAS ..................................................[ 40
tRC ...................................................[ Auto
tRRD ..................................................[ Auto
tWTR ..................................................[ Auto
tWR ...................................................[ Auto
tWTP ..................................................[ Auto
tWL ...................................................[ Auto
tRFC ..................................................[ Auto
tRTP ..................................................[ Auto
tFAW ..................................................[ Auto
Command Rate (CMD) ....................................[ AUTO
IO Latency ............................................[ Auto
Round Trip Latency ....................................[ Auto
Channel B Timing Settings:
##Channel B Standard Timing Control##
Advanced Voltage Control:
CPU
Load Line Calibration .................................[ Level 1
CPU Vcore .............................................[ 1.44
QPI/VTT Voltage 1.050v ................................[ 1.15
System Agent Voltage 0.925v ...........................[ Auto
PCH Core 1.050v .......................................[ 1.1
CPU PLL 1.800v ........................................[ 1.8
DRAM
DRAM Voltage 1.500v ...................................[ 1.64
DRAM Vref 0.750v ......................................[ Auto
DRAM Termination 0.750v ...............................[ Auto
Ch-A Data VRef. 0.750v ................................[ Auto
Ch-B Data VRef. 0.750v ................................[ Auto
Ch-A Address VRef. 0.750v .............................[ Auto
Ch-B Address VRef. 0.750v .............................[ Auto
Miscellaneous Settings
Isochronous Support ...................................[ Disabled
Virtualization Technology .............................[ Disabled
you need more vcore man, SB OCing is so simple.
lol and most chips are sucking. BTW back off the ram, do one at a time.
Yeah saw a fail chip on OCN...2600k needing PLL for x45....
i set vtt to 1.18 booted into windows @ 53x
jumped to 55x
what safe max vtt lol
tryin to boot @ 53x again:rofl:
EasyTune6 (Intel) B11.0323.1
http://download.gigabyte.us/FileList..._et6_intel.exe
i was using sata2 ports
windows is fried :rofl:
its lookin that way
i couldnt even reload windows on sata3
i'm reloading windows on last sata2 ports
does your sb heatsink get hot?
mine @ 35c runnin stock reloading windows
i'll play for another hour n clean up the board
2 sata2 ports are gone
@ least i know cpu good for 53x
