I'm on POH as it has Auto Express in it.
I get the problem on the HT multi not going down again as well as the FSB not going down again, but its easily fixed buy saving your settings before upping the FSB/ HT-MULTI so if they get stuckup i just load the old ones.
If you have not done that beforehand load optimised defaults works for me as well but is a pain to have to reconfigure the bios from scratch.
Checking with cpu-z to see if all is well.
This thread surely died. No one overclocking 9600/9600BE's anymore?
9600BE..Its gone frome 2.6ghz Max stable in xp32bit to 2.3ghz Max Stable under Vista 64bit...
Mine has the Cold bug problem and and buggy IMC,,
it only likes Low Volts but wont work at stock volts...
Ive been holding out as long as i can before i send RMA for another replacement.Had two of these so far 9600BE,,the 9600standard is way better.
I hope they start giving B3 replacements soon..
@stock a B2 is Nice ,,Overclocked its more than a gamble and no where near what a B3 does 24/7.
