"Ghosting" a RAID 0 system
Cheers! First post and great forum.
Just a heads up for anyone wanting to "Ghost" their RAID 0 system using Norton Ghost.
On all the systems in my home I've always had the operating system on a drive about 8 GB. and made a "Ghost" image of it.
I have a P5W DH Deluxe and wanted to try RAID 0 (for performance) and ghosting it. I have two 320 GB Western Digital SATA drives I put on the EZ Raid connectors. Norton Ghost 9 had no problem making an image file, or restoring it.
The more I read on here, I realized EZ Raid wasn't the optimum way to go for performance. I connected the drives to the SATA 1 & 3 connectors, started over, formated and re-installed XP and some other goodies.
I created a ghost image of the operating system drive, no problem.
When I tried to restore, Norton couldn't see the D: drive where the image was, or any drives for that matter. Using Norton's Recovery Disk to boot with, and hitting the F6 key to load drivers didn't help. It appeared to load them, but didn't use them.
Checking Symantec's website, Ghost doesn't support any version of Raid unless it can access it through DOS, and even then it's iffy. My drives are formated as NTFS, so DOS is out of the question.
So having any Raid (other than the EZ Raid) on an NTFS partition isn't going to fly with Norton.
In conclusion, I did manage to make an image file of my C: drive and successfully restore it using Acronis True Image 9. (Raid 0 on SATA connectors 1 & 3)
I hope this saves someone all the time and effort I spent screwing around trying to get Norton to work in this configuration.
