no, i cannot explain the "n/a" so don't even ask.... :)
http://members.cox.net/kjboughton/FCG_155507.jpg
kyosen you crazy guy :toast: :toast:
And no we are not getting sick of PI :D
FCG it's not wise to taunt this guy with 5 points only ;) :D
kyosen thats amazing:toast: ...Aquamark3 is in...again:)
OMG. Realy need some cash for some CF damage :) results are.... well, we know what they are.
:toast:
WOW....may I ask - So is your cpu NOT FSB limited? Are these results basically due to the ACTUAL physical limit of the cpu? Thanks.Quote:
Originally Posted by kyosen
Many thanks to all:)
s7e9h3n> So is your cpu NOT FSB limited?
s7e9h3n> Are these results basically due to the ACTUAL physical limit of the cpu?
My CPU is FSB limited at around 282MHz...
It can boot up with FSB=280 BIOS setting under DryIce or LN2 cooling.
In my case, there is no difference for FSB limit between DryIce and LN2,
and DryIce or LN2 gives about +15MHz FSB gain compared to water cooling.
freecableguy> no, i cannot explain the "n/a" so don't even ask....
Hahaha, anyway Conroe seems a promising CPU for AquaMark3;)
Thank you for the reply :toast:Quote:
I noticed that you run the same cpu speed for 2M - 16M, but different speeds for 1M and 32M. Is there a reason why the cpu can't run ALL the benches @ the same speed as 1M? Sorry for all the questions. It seems as if you've figured out the mystery to these cpu's while the rest of us are still in the dark :D Thanks again....
Since when can we run 32M at the same mhz as 1M ;)
I'm sure kyo could run faster on 2M, 4M ect but not many guys go to the extent of determining max clocks on each of those tests. So how is your Yonah doing Stephen? Did you get it to cooperate with the cascade yet?
One thing that is missing from Team Japan I am curious about. Container temperatures with DI or LN2. Are they running full LN2 temps or controlled? I'm guessing the latter. A few of the scores posted up mention alcohol rather then acetone with DI maybe for higher temperatures. It would be interesting to find out more on that.
normaly you get this when booting at low speed and go much up in windows with clockgen.Quote:
Originally Posted by freecableguy
cbid reports a maximum speed , and above that you get the n/a,
higher fsb at boot solves this problem.;)
WOW kyosen that's amazing show you do for us here :toast:
and I will never get tired of pi and if one can break the 15s - no question who :D
Very nice done mate! BTW where's the 8M? :D
Rather disappointed by my cpu step 4, fsb wall @ 223 :slapass: on air, any multi
Board rev 00A, bios 1.03
Now, I even don't wanna bother installing vapo on it ...
lol my old dothan 750 did 270 on air
same here in GermanyQuote:
Originally Posted by kiwi
business like usual ... 90% of all stepping 4 have their problems
while retail or stepping 8 cpus >week 40 /05 seem to be better
i think we will see the new D stepping retail yonahs appearing in 3 or for weeks
so I think the Aopen i 975x may show its full potential :-)
right now 282 fsb is the highest fsb we saw so far.
I made a quick test 1M with this CPU and multi 10:
http://www.computerbase.de/forum/att...8&d=1143359786
260 MHz on AIR
What's "this" cpu? :D Any particular one discussed earlier in this thread?Quote:
Originally Posted by stummerwinter
my aopen does 300 MHz FSB und 295 MHz FSB stableQuote:
Originally Posted by mine
I just want to point out, that my T2600 ES (8, week 39 (?), QKHK) can do 260 MHz @ air on my Aopen...;)
So, no FSB-wall for this stepping...;)
Sure would like to see a ss of that. It's the most fsb I've heard of. Please post one at 295 with spi 1m, thanks.Quote:
Originally Posted by albertwesker
OS was changed.
Today'S BEST Result;)
M/B: AOpen i975Xa-YDG改(#1)
CPU: T2600ES
CPU Cooling: ARARE'S POT#2&LN2
Memory: CORSAIR PC2-5400C4 V5.2 512MBx2
VGA: X800GTO
HDD: S-ATA WD1500ADFD
Power Supply: Zippy-500GE(3.3VRAILMOD)
Vcore: 1.63V, Vdimm: 2.46V
OS: Windows Server 2003
MEM: 4-3-2-1 3:5
Vio:3.78
http://cal930.sakura.ne.jp/cgi-bin/c...e/16172_1m.png
Very nice Cal :woot:
mine's best for now :
http://img153.imageshack.us/img153/8509/167034te.png
CPU: T2600ES QKHK 8
CPU Cooling: Single stage ... :D
Memory: 5400UL - 443Mhz 4-3-2-2
VGA: Matrox Millenium PCI
Power Supply: PCP 510w
Vcore: 1.64V, Vdimm: 2.40V
OS: Windows XP SP2
What is VIO voltage? And how is it "adjusted"?Quote:
Originally Posted by CAL930
ZIPPY500GE 3.3VRAILMOD=ZIPPY 460WS 3.3VRAILMOD:)Quote:
Originally Posted by s7e9h3n
Ahhh...so it's the 3.3V rail Voltage? Thanks :toast:Quote:
ALL updated :D
@ tyrou :O single stage pwnage
Can you guys run hexus pifast on those speeds :D
