AND LOLOLLOL :rofl:
Rofl.
My Rig
Spec In Sig
Finger Prints Everywhere :(
Cyco , I might be wrong but i think the heatpipes on the si-128? are incorrectly orientated. I might be wrong but thought i would share :)
i do like the match of the blood iron (excellent board) and the red ram heatspreaders! perhaps you should spray the gpu mesh red too ;)
That orientation is fine for the cooler. IIRC the orientation where the heapipes are facing downwards is the wrong way.
ah, always thought they had to be horizontal :D my mistake.
Plus that way it helps to cool the northbrige.
good point cyco!
My case is not long for the Aircooling world :)
Its being taken by the darkside of watercooling :up:
Enjoy it till it leaks and destroys your components :up:
jk jk :D
didnt you just replace your 3870 heatsinks dude?
Yep I did :)
To requote Spawne from earlier....
http://i11.photobucket.com/albums/a1...ballin1tg1.gif
I made a simple suspension mod for the hd's :)
http://koti.mbnet.fi/nazu/Kone/hdsuspension.jpg
We don't need you here anymore then =[
