the first memory kit has d9gmh? and the second? d9gkx?
I got the first one, and i think they have micron D9gmh chips, but mine don't do well, not Cl4 1000MHZ at 2.2V, even not booting, and 1200mhz even not with 2,3V, i think i didn't got the best one, but you can try your luck and get one, but from know on, i prefer only used DDR2 from eBay or anywhere else because they're cheap ( the most expensive one about 30€ ) and if they don't overclock well, you can sell them.
Hope could help you
But
still
go
Team Xtreem:up::up::up::up::up::up::up::D:D:D:D:D:D
Hi Guys,
I have a set of Corsair Dominator 8500C5D's (2x2gb) v2.2. I've looked at the IC's that are on the set, and all i can gather from the corsair forum is that they are Micron.Gdies.
What IC am i looking at here and what sort of clocks can i expect from them?
I'm reaching 1098mhz on my DFI DK-790FXB-M2RSH with a 940BE at 2.1v. I haven't really tried any other volts as i don't wanna kill em quicker.
Anything after 1098 i get multiple errors in winmemtest but everything else passes perfect! :(
OCCT Linpac test runs for approx 30 mins before i cancel it and no errors whereas memtest runs less than 2 mins and finds 2 errors.
I can get it posteable until 1200, and it gets into windows perfectly fine, until i run a bench then it dies (i'm actually guessing it's my IMC when this happens as it's running @ 2.75ghz.
Any help with what IC is on these sticks, and possibly with some timing/safe volts/speeds would be awsome!
Thanks guys! :)
Theses mems ics aren't microns.
hmmm, here´s from Corsairs forum, the DDR II IC Inquiry.
TWIN2X4096/CM2X2048-8500C5DF
........................XMS850X v1.1...PSC.C-Die.......128MX8
........................XMS850X v1.2...PSC.F-Die.......128MX8
........................XMS850X v2.1...Micron.E-DIE...128MX8
........................XMS850X v2.2...Micron.G-DIE...128MX8
........................XMS850X v3.1...Elpida.C-Die....128MX8
........................XMS850X v3.2...Elpida.F-Die....128MX8
As i said... they are micron g-dies (what ever the hell those are! :P)
I can't seem to get anything out of them! even setting 2.3v @ 1120 i get fails on OCCT linpac.
With the gigabyte board i had them running at 1160 @ 2.35v perfectly fine, just on this dfi board there are subtimings i cannot figure out for the life of me! :(
if any1 can help me out that'd be great!
ok i figured out what the issue was.
I only pumped 2.35v through them for 5-10 mins to see if they would pass memtest (within less than a min they would error).
The issue was with subtiming (TWR and TWTR being too low).
I used memset to find some of the subtimings from SPD. I'm now able to pass memtest @ 1120 @ 2.2v with 5-5-5-15-4-22-8-4.
Thanks for the help though guys, i'm a much happier now that i can get 12kmb/s copy and 11kmb/s read! :)
Thanks guys! :)
What is a safe voltage for a g-die btw?
*Yes at 1066 it passes perfectly fine*
No more than 2.2v. 2.15v to be safe.
I have 3 crucial sets
1. tracers 1066 - 600 5-5-5-15 spi32m stable on 2.12v, but can't stabilize them under dos version of memtest even at 2.2v - any clues?
2. tracers 800 - 575 5-5-5-15 memtest stable on 2.2, can't make 600 even at 2.5v,
3. lanfest 800 - can't make 600 even at 2.5v, haven't tested lower frequencies.
Any clues guys?
That's what I don't get, how can 3 totally different sets of mem don't oc at least to 600 5-5-5-15.
Haven't got bigger problems with ocing promos to such frequencies but d9 is a nightmare. :(
Lets give us some info about your Board, maybe your board isn't the Overclocker, what about Northbridge Voltage ?
Rampage Formula as it says in the signature, I've tested up to 1.6v on mch.
Does ANYbody of you know, which ICs are under the first generation OCZ Flex XLC Edition CL3
http://p.gzhls.at/239656.jpg
thanks
http://img82.imageshack.us/img82/7893/pamitki.jpg
Tracer Ballistix, Handpicked D9GMH's
How about that? :D Only 2.1v
What do you think?
Nice tRAS.:)
Found this ones:
http://www.abload.de/thumb/2x1gbcell...2-8000ggvr.jpg
Could give voltage up to 3.0 volts under air but it didnt do anything.
Very nice rsults on AMD system, :up::up:
today i got my uses 4*1GB OCZ Flex XLC 1150, on single channel they boot up with 2,8V, but going to take them under cold ( I have to reach the 1600 before dieing :] ).
Got some nice Ram from OCZ here, Flex XLC 1150 Cl5,
here some CL4 testing,
Set up:
Q6600
P35 DS4
OCZ Flex XLC 1GB 1150
Excelstore 80GB
Jetway 8800gt
NoName Watercooler
Coolermaster M620
3* Xilence Redwing 1200rpm
here some Validations and Screenshots:
Vaildation @ 1278 Cl4 4-4-4-15 2,8V set, 2,84real
http://valid.canardpc.com/show_oc.php?id=782831
Screenshot 1260 Pi1m
http://img14.imageshack.us/img14/423...xlccl41260.jpg
