Have you tried running Prime95?
VID is 1.225, boots easily at 445x9 with 1.225 in bios. Next stop 1.2 in bios, which may not work :D
4GHz @ 1.2000 in BIOS, not stable (no surprise there) but I got a photo of sub 1.2v :up:
http://i293.photobucket.com/albums/m.../4ghz1192v.png
One goal achieved, next goal is to boot at 4.5GHz :D
you got that cpu directly from intel?if not where did you get it
Hello guys,
Do you think it is safe (for cpu & motherboard) to run my Q9650 H24 @4.2GHz ?
In the bios :
- vcore : 1.3V (1.29v with cpu-z)
- vfsb : 1.28
- vnb : 1.26
My computer :
Asus P5Q deluxe (bios 1306)
Q9650 (9*467MHz)
2*2048Mb Pi Black 8500 Gskill
Cooling : Ifx14-10
Temperatures: in full mode, below 75°C under linX
Thank you very much for any help
Nice this is mine ;) L828A446 vid 1,1875 on low volts does magic till 4300
http://img530.imageshack.us/img530/3709/sergio4005.jpg
Cheers :up:
Sergio
VTT is the same as VFSB, right?
Well to be more precise my temperatures (under linpack, so full load) are as follow:
Cpu : cores between 70 and 77°C
Mb : 35°C
My case is a P182 with 7*120mm (scythe Slisptream 1200rpm) and a scythe KamaBay.
Fortunately ambient temperature do not exceed 25/30°C even during summer :yepp:
Thank you again
Aahh good, i wasnt sure about that :D
Got mine down to 1.304v under load for a prime pass (2 hours), temps under 66*c now....i wonder if i can go much lower...
I bought it on ebay and the seller got a replacement from his supplier under warranty - could have been an "official" Intel channel.
_______
General remark to all: I'm very happy with 4GHz so there's no need for me to join the :cheer: Gigabyte UD3P :cheer: cheerleading squad.
:p:
Mines an A2, but I was under the impression the MF2 were better. :shrug:
Agreed it's not the best mobo for high fsb+quad, but it's still possible and has been done a few times - Grnfinger did 500x9 with his Q9650 four months ago, but it did take a lot of tweaking.
I'm happy with 445 fsb, 4GHz is plenty :p:
All I need is to get it stable on 1.216v, play with some GTLs and skews :D
