Originally Posted by
Gr1mR34p3r
I need some explanation on these settings.
1. FSB Strap to north Bridge
Is use only 1:1 and 5:6, 5:6 is no problem as it only works with strap 333, but which is better for 1:1, 333 or 400? Normally lower strap is faster, but needs to be verified on each board regarding stability, max clocks etc...
2. DRAM Static Read Control: Auto/Disabled/Enabled, currently on Disabled Enabled gives more bandwith, but I advise to disable at first , try to find stability and then to tweak... but enabled is faster
3. DRAM Read Training: Auto/Disabled/Enabled, currently Auto can help for higher ram clocks and stability, bios says it all
4. MEM. OC Charger: Auto/Disabled/Enabled, currently Auto same remark a above
5. AI Clock Twister: Auto/Lighter/Light/Moderate/Strong/Stronger, currently Auto I haven't noticed much difference between Stronger and Strong... I set at AUTO first then go to Moderate, test everything and then try stronger, if ya having ram issues or incompatabilities some set Light or even Lighter
6. CPU Spread Spectrum: Auto/Disabled, currently Auto General rule to Disable when OC'ing
