I don't have any airflow around it AT ALL. Let's see when this will explode then!
CPU-Z, version 1.44.2 beta:
http://rapidshare.com/files/95634677/cpuz.zip.html
I also agree this is an awesome board. Im using the F6 bios (not the best for FSB) and was still able to run superpi32m @ 505x9 (on air). Im going to flash to F3 which seems was the best for FSB. I was able to hit 525x9 and boot into windows but spi1m would error on 5th loop (did this @ 1.55v bios, 1.48v actual).
When I get my QX6850 ES on Wens Im gonna do some action with the F5H/F5G bios. This is supposedly the best for a quadcore right?
CoreTemp 0.97.1 is out:
Version 0.97.1 - 7th March, 2008
- Fix: Phenom did not display proper temperature in version 0.97.
- Fix: Phenom randomly reports 255C (value ignored).
- Fix: Phenom displays more than a single system tray icon per CPU.
- Fix: Phenom 1/4 multipliers rounded improperly.
- Change: C° and F° now will display °C and °F accordingly.
GA-X38-DQ6 -- F8 Bios version :)
http://www.gigabyte.com.tw/Support/M...ProductID=2665
GB driver page got updated, nothing i haven't linked to already though:
F8 works great for me too! I guess this board is finally getting mature :)
I guess I will have to give F8 a whirl. What type of improvments have you guys noticed over earlier BIOS?
F8 sucks!!!!...the 2.50A multi no longer works...tried everything and it wont POST any longer. I have to use 2.40B multi but my memory is now running at 1020MHz as opposed to 1063MHz!!!!
Thanks GB...idiots.
Regarding the EX38-DQ6, strangely enough, I drove a Prius for the first time last week when I rented a vehicle in Los Angeles.
IMHO, the EX38-DQ6 and the dynamic power saving is somewhat analogous to driving a Prius.
It's interesting to watch the system clock up and clock down, with what looks like dynamic adjustment of both clock and voltage.
Power is getting pretty costly, but in terms of computing costs, it's still pretty small. Where I'm at, electricity is about 3.3 cents per kWh, a 50W reduction in power (if that is even possible with this mobo), running 7/24 equates to only $14.25/year. Not really that significant, but I don't know yet what the maximum reduction would be. (I doubt it would be more than 50W though) I have a Kill-A-Watt meter, so I will be trying that in the near future when the system is overclocked to see how it does with dynamic power reduction.
I'm still trying to get my system together right now so I haven't starting overclocking yet. Originally, I put my 4-drive Matrix RAID10 + RAID5 array onto the DQ6, but it didn't boot from the array properly, so I had to create a new array. This time, I didn't bother with the RAID5, but just did RAID 10.
Strangely after I installed Windows, something happened (not sure what), but it appeared like I lost 2 drives. There were 2 drives that if connected to the Intel SATA on the mobo, would cause the mobo not to boot. However, connected to the purple JMICRON SATA ports was no problem at all.
So, I connected those drives to the JMICRO SATA, reformatted. Updated the BIOS to version F2, moved the drives back to the Intel SATA and everything is working again. So I'm going to try to create the RAID10 array and then restore my backup.
It takes several hours each time, so each night I can do 1 run at this. Hopefully, I can get my system fully restored, then I will try overclocking.
Well, i need to SEE the CPU being listed as supported to be sure/safe.
2.5A works just fine here. Obviously they keep changing alot of stuff, and various types of memory will require different settings to compensate. My understanding is they actually FIXED 2.5A.
There still seems to be some very strange behavior in how the BIOS determines TRD though.
For some reason, some straps seem to only allow the lowest possible TRD at CL4, not CL5. Fairly counter-intuitive imo...
Should i update my bios, i'm not having any problems with the version i have.. Would there be any gain from it?
http://www.gigabyte.com.tw/Support/M...ProductID=2736
I'm using F1 still (X38-DS4)
Would it be worth the trouble? :shrug:
The power saving may not be much but its something, think about it in equation to all the computer users in the world, the savings would be tremendous.
At the end of the day it shows that Manufacturers are slowly making an effort to curb greenhouse gases. Eventually we will all have to play taxes on the emmitiones each individual puts out.
