There is More !!
[hwbot] WeldZilla- 260767 - 8400 air @ 4689 - 8800GTX 660-1075 stock air [/hwbot]
http://img.photobucket.com/albums/v2...la/aqmk3cc.jpg
WZ
There is More !!
WZ
Keep trying, WZ. Tighten that ram up!
[hwbot] cadaveca -262595 - E8400 @ 4500Mhz - HD2900XT 512MB Crossfire @ 822/900[/hwbot]
Like this:
[hwbot] cadaveca -263432 - E8400 @ 4500Mhz - HD2900XT 512MB Crossfire @ 822/900[/hwbot]
Hey cadaveca good to see you pushing it! I got you on the cpu score but, it will be hard to overtake 2 x 2900 cards in X-fire. You know I'll try!!
[hwbot] WeldZilla- 263645- 8400 air @ 4563 - 8800ultra 705-1200 stock air [/hwbot]
WZ
This one is for you Dave! Don't get scared now!!
http://img.photobucket.com/albums/v2...la/aqmk3b1.jpg
You notrice by lowering my fsb down and changing mem speed and timing I was able to duplicate your cpu score and then I simply put a little crush on your 2 2900's and there you have it!
Now come and hit me back!!!
[hwbot] \/ENDE][A - 206602 - E6600 @ 4031.4Mhz - SLI 7900GS @ 710/1960Mhz - All air cooled - [hwbot]
http://www.hwbot.org/result.do?resultId=700139
0h cadaveca.....you mean like this!
http://img.photobucket.com/albums/v2...lla/aqmk3e.jpg
I won't hwbot it here as I do it for BE. I just wanted to showit off!
Hey dave have you experimented with your multis available??
Give them a try if you haven't With your X-fire set up I could see you pass 270 or at least push it hard!!!
WeldZilla
Nah, I meant a bit more like this:
[hwbot] cadaveca -269625 - E8400 @ 4590Mhz - HD2900XT 512MB Crossfire @ 833/900[/hwbot]
Your ram timings are not optimal yet, WZ, my cpu speed has been less all along, yet more efficient, with looser timing @ 5-5-4-15 I'm surpassing your score.:yepp: Could be partially due to driver too...:shrug:
Keep pushing, I got more in my back pocket for you...;)
:up:
Here's 272k, just for you, WZ...
[hwbot] cadaveca -272261 - E8400 @ 4635Mhz - HD2900XT 512MB Crossfire @ 833/900[/hwbot]
I believe there is a chipset difference coming into play here dave. That is really a magnificent cpu score. Congrats....
WZ
[hwbot] \/ENDE][A - 201485 - E6600 @ 3869.6Mhz - Single 8800GT 256Mb @ 760/2040/1900Mhz - all air cooled - [hwbot]
http://www.hwbot.org/result.do?resultId=703994
oh dave, you whoooooo......
I stuck my new as in I just got it today. E8400 into my P5e mobo
As you can see my cpu score has gone up a bit. The miserable weather here has warmed up!! yuck!! But, I think this board ,proceesor and me will get along just fine!!
Hey my single card is hanging with yout 2 2900XT's in X-fire pretty darn well.
I only bring all this up dave cuz I miss ya.
http://img.photobucket.com/albums/v2...lla/aqmk3a.jpg
WZ
You gotta do better than a couple hundred points, WZ, I'm disappointed!
(521x9 1:1, 5-5-4-15)
[hwbot] cadaveca -274225 - E8400 @ 4690Mhz - HD2900XT 512MB Crossfire @ 833/900[/hwbot]
There you go again.......
You are using a more expensive board and 2 vid cards, now these are not just run of the mill cheap little cards either. Yet I keep on passing you.
My cpu score is whipping up on yours :yepp:
you are running your mem loose as a goose!! While mine is running higher and tighter. :rolleyes: I only have one little Vid card in my case that was purchased dirt cheap on ebay.....:up: and yet here I am again haunting you..... So better go crank it up some more and hit me again!!:shocked:
Oh by the way you are not the only one with a couple scores in his back pocket...
All kidding aside it is good to see you also squeezing so much cpu power out of your 8400 too. Feels like old times! Hey dave I am thinking about installing vista on one of my machines. Which Vista ver. should I go with?
I look forward to you whacking me back soon!!
http://img.photobucket.com/albums/v2...Zilla/aqff.jpg
As you can see the only thing keeping you in this game is your 2 vid cards!!!
Come and catch me if you can!!
WZ
[hwbot] loc.o - 287029 - E8500 @ 5200Mhz dice - 3870 CF @ 850/1250 stock air [hwbot]
http://img.photobucket.com/albums/v636/loc_oc/AQ03.jpg
[hwbot] \/ENDE][A - 227628 - E8400 @ 4005.1Mhz - Sli 7900GS @ 710/1960Mhz - all stock air cooled - [hwbot]
http://www.hwbot.org/result.do?resultId=715847
[hwbot] \/ENDE][A - 228407 - E8400 @ 3960.2Mhz - Sli 7900GTO @ 731/1900Mhz - all stock air cooled - [hwbot]
http://www.hwbot.org/result.do?resultId=716204
[hwbot] \/ENDE][A - 200030 - E8400 @ 3960Mhz - Single 7900GTO @ 742/2008Mhz - all stock air cooled - [hwbot]
http://www.hwbot.org/result.do?resultId=716526
[hwbot] Memory - 262807 - E8400@4400mhz - HD 3870 CF @ 800/1170 & 777/1126 - G.Skill GBHZ PC12800(1600)@ 1433mhz @ 7-7-7-18@1.7v-Gigabyte X48T DQ6 - All Air [/hwbot]
http://i234.photobucket.com/albums/e...iew/262807.jpg
[hwbot] Memory - 265744 - E8400@4545mhz - HD 3870 CF - G.Skill GBHZ PC12800(1600)-Gigabyte X48T DQ6 Rev 1.1 - All Air [/hwbot]
http://i234.photobucket.com/albums/e...iew/265744.jpg
[hwbot] Memory - 270929 - E8400@4545mhz - HD 3870 CF - G.Skill GBHZ PC12800(1600)-Gigabyte X48T DQ6 Rev 1.1 - All Air [/hwbot]
http://i234.photobucket.com/albums/e...iew/270929.jpg
[hwbot] The Nemesis - 210929 - q9450 @ 3700MHz - 8800GTX @ 650/1026 stock air [hwbot]
http://img.techpowerup.org/080527/Aq...-1026 shot.jpg
- invalid screenie :)
[hwbot] \/ENDE][A - 288524 - E8600 @ 5000.2Mhz - 3850 X2 @ 668/828Mhz H2O/Air - [hwbot]
http://i834.photobucket.com/albums/z...4wsbH2Osml.jpg
