Originally Posted by Zeus
260 should be a walk in the park even at lower voltage.
Set every timing to auto except for the 2-2-2-5 settings, run memtest 86+ from bios and tighten the timings one at a time and rerun memtest 86+ after each change.
That's the only way to find out what holding you back.
Doing so i found that my MAL set to 8 was too tight, something i never thought about changing but it worked like a charm, i went from 256 up to 269 memtest stable.
Also, 3,66V is a bit much for 260MHz, start with 3,4-3,5V.
Last Viking, i'm curious what you can drag out of your sticks, c' mon man, show some sick numbers. ;)
I'm gonna play around some more with Data/Drive strenght to see if my sticks will take 3.7V, hoping to get a few more MHz outta them.
