thanxs wdrzal, good to see ya around again :clap:
correct, i normally have one have it on there for the iniatal charge when load testing in the shed. then when finished turn the cooler off and wait till she cools down then take gauges off (high side) when pressure alot lower. i take suction hose off when system is running and in positive pressure and loose almost no gas.
WHen tunning inside and doing small tweaks just use low side gauge/hose and not bother with the high side. i know max high sider pressure when i give the cooler 270w :yepp:
Heres the first silve case frozen SS i have made. Basically finished just need to do some benching
1/5hp with r404a refrigerant
http://img164.imageshack.us/img164/1700/dsc02337qb8.jpg
http://img87.imageshack.us/img87/3566/dsc02338qc7.jpg
Picked up a bunch of push pull fans condensers, cant wait to uses these babie :bounce:
http://img127.imageshack.us/img127/9458/11sy7.jpg
http://img186.imageshack.us/img186/7626/kayl5zl0.jpg
heres a new 3/4hp units im working on
http://img104.imageshack.us/img104/7666/22fc7.jpg
http://img134.imageshack.us/img134/7902/33un0.jpg
