wow servers are struggling already, I am getting about 37kb a second
yeah servers are in the crapper... im getting like 58kbps on a T1.. which i average ~1.4megs.
sucks.
I recomend guru3D servers. I'm getting 142kb/s on adsl.
I guess this makes a 920 look more attractive than a 641 for me, even if I couldn't do well in this if I wanted to.
bittorrent ftw! 330kb/sec
You can whine and :banana::banana::banana::banana::banana: all you want about it, but you know what? This is what people are going to start using for comparison. Its like the snowball effect, once you get people going, you can't stop it.
Can't wait to run this on my home system :)
Decided to buy the pro version cuz all the other download servers are bogged down, 4 hours?? I'll be getting mine in <40 minutes
only $15 for the upgrade from 05 pro =P
Got mine in 20min, didn't have do spend a €... Portuguese mirror... Probably doesn't work for you tough, we got really bad connections to the outside...
I'm not gonna run this test anymore.
Infact this was insanely boring, GT1 GT2 is exactly the same as Gt1+GT2 in 3dmark05.
http://service.futuremark.com/compare?3dm06=1601
Yeah, the new tests are the ones you can't run :( Don't think the CPU formula is quite right... But oh well, bring on the FX-60/Presler...Quote:
Originally Posted by LenniZ
A64 3000+ @ 2600 Mhz
X800GT @ 590/590 (Clocked a bit)
Test made @ 1280x1024
1506 marks (with LOD +2)
http://service.futuremark.com/orb/pr...projectId=2053
I am having problems unzipping the file, whenever I try to unzip it it says there was a diagnostic error
any ideas?
Filefront servers are fast. I'm getting 600kB/s off distro #10.
where did you download it from?Quote:
Originally Posted by payne280
It sounds as if the file is corrupted.
i downloaded it from guru3d
downloading it from filefront will see if it is my computer or corrupted file
FEEL THE PAIN !!! ROTFL
http://service.futuremark.com/compare?3dm06=2574
Ran @ 1024x768 not 1280x1024, just because i'm on a 15" monitor :)
975 sm2 points.. i didn't bother to run through the cpu tests to see the hdr
tests. god, i saw a pic every few seconds in the first cpu test, supposedly every 2 seconds a pic. wtf. and yea, the first 2 tests (sm2) are basically 2k5
with a little extra (i think, or the textures were just acting up). whatever
975pts on a 6800gt @ default on an pm760@240x10 5-4 192-5-2-2-2 lol
To sky :
Pretty low score...:(
what's your score....975? or more
check that :
http://www.pcper.com/article.php?aid...e=expert&pid=1
There is the full review...:)
The CPU tests are really painfull... A 6800GT should get at least 2600Marks... I'll try it on my GS later...
I'm seriously thinking on running it on a FX5200 overnight...
It runs on Cards with 128Mb, and less than 1Gb RAM... But surely it will break performance...
guru3d has a password check thier review for itQuote:
REALLY painfull... My A64 couldn't achieve more than 1 frame per second... =XQuote:
Originally Posted by God_Lx
Same here, this really sucks, I can't imagine anyone, either single or double (SLI/Crossfire) card(s) enjoying watching this :mad:Quote:
Originally Posted by X3non
I believe there's no CPU that could make 1fps average yet... But where are the big names ? Sampsa ? macci ? K|ngp|n ? Shamino ? |RickY| ? (And many others course...)Quote:
I don't even get to the option of putting in a password, as soon as I hit extract it says there is a diagnostic error
it says file is not supported archive whenever I right click and go to extract
Where can i find this password? link
tnx
